Karl 0 Posted October 20, 2009 I finally had enough of wrinkly application tape pulling letters out of place, I got a dispenser -- got a do it yourself version from ebay, "Premask Application Dispenser DIY" , I could have bought a prebuilt, but I like the idea of being able to make more, and adjust the size to my needs. anyway, once I started using it, I can't see myself not using it. Too easy. made a short video to show what I wanted to know before I bought mine, I wanted to see if it were really worth paying for. -- cant upload video here, have to post and put link here, so 4 photos instead.-- hope this helps you if you are trying to make a decision on one of these devices. Share this post Link to post Share on other sites
jmmccann 0 Posted December 4, 2012 Do you have a seller I can contact for this? I can't seem to find the product anywhere? What are the materials used to make it? Share this post Link to post Share on other sites
GreenTech 3 Posted December 16, 2012 I just got the one from US cutter. Worth every penny. Cuts your application time in half and improves quality. APPRoller Tape Application. Share this post Link to post Share on other sites
Monkey 252 Posted December 16, 2012 I just got the one from US cutter. Worth every penny. Cuts your application time in half and improves quality. APPRoller Tape Application. I use that same one and it makes apllying the tape really easy. Plus with the lip on the one side it keeps it from moving while pulling the tape as long as you put it on edge of table. Just pull tape out the length you need, slide vinyl under it and use squeegy to stick tape to it then cut the tape, reroll up and put tape back in bag. Share this post Link to post Share on other sites
