haumana 1,220 Posted October 14, 2009 Does anyone know how to make them all work together? There was a previous post from a user who had an LP and was running Fusion. I'm in the same boat I'm running Fusion so I can get to SBE without having to do a reboot to an XP to layout and cut. I'm using a keyspan because the cutter will vibrate the USB connect loose. It worked when I booted directly to XP, but I'm trying to cut through Fusion and I can't get squat. I've installed/uninstalled/installed (several times) the drivers for the keyspan device. Has anyone out there gotten this combination to work? or does anyone have any advice on how to get it working? I don't have the cash to to sink into the Flexi cutting software for the Mac side yet. Share this post Link to post Share on other sites
haumana 1,220 Posted October 14, 2009 HALLELUJAH! I figured it out ... dang! I needed to open up the settings on the Fusion s/w and enable that particular device. You'd think that Fusion would just enable everything that's connected to the computer. Anyway, I got it to work. Only time will tell if it proves to be a stable / consistent connection. Keep your fingers crossed!! Share this post Link to post Share on other sites
