lexiprice 1 Posted October 13, 2009 I've been able to edit a ton of fonts- now the nodes aren't showing up on the font. There's two little boxes at the bottom of the letter, but that's it. Did I change some setting to make it do this? Is there any way to get it back? Thanks! Share this post Link to post Share on other sites
prestonservco 26 Posted October 13, 2009 I've ran into this a couple of times. Sometimes while editing nodes, I loose track of where the existing ones are, so I quickly F6 then F5 (zoom in / zoom out) which refreshes the image for me. Other times, I select Node Edit in the menu bar and that forces the software to display all of them. It's just a glitch. Share this post Link to post Share on other sites
sarconastic 29 Posted October 13, 2009 You will have to convert them to curves to edit the nodes. When ever you make changes to a font like outlines out blocking the program changes it to curves automatically. That's probably why you have been able to edit the ones you have before. In the program click the text you want to convert, then select "arrange" then "Convert to curves" Kevin Share this post Link to post Share on other sites
lexiprice 1 Posted October 13, 2009 You ROCK! Thanks for the quick answer- Kevin that totally worked. Thanks so much! Share this post Link to post Share on other sites
sarconastic 29 Posted October 13, 2009 no problem, just make sure you pass it on when you get the knowledge. That's why were here :-) Kevin Share this post Link to post Share on other sites
Darryl007 1 Posted October 22, 2015 Thanks for the tip! Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 23, 2015 Just a heads-up, there's another way -- on the toolbar is an item called "Text-Grap" which when applied, allows you to choose each letter individually and node edit it (double-click on a letter after applying the text-grap). 1 Share this post Link to post Share on other sites
