thosmhicks 0 Posted October 25, 2007 This worked for me-- Hope it works for you. I'm using SignCutX2 V2.18 on a Redine MH721 click on the hammer and screwdriver button at the top tool bar. Select the "Use external corner registration marks" box. This is the last thing that is cut (in my deigns it works that way..) and the last registration mark is right next to the origin- so there is no design to be cut between the last cut and the origin.( and if you have the "Weeding Box" checked, it also seems to make it cut that as well) It's a work-around, not a fix-- but it works. Share this post Link to post Share on other sites
WalterD 0 Posted November 15, 2007 I had the same problem of blade cutting accross the design. Not only at the end of the cut to the home position, but during the middle of cutting. I had bought a KEYSPAN adapter from Amazon.com and the cutter and software are working perfectly. I did not believe that was going to do the trick, but it did. $31 is all it took. HIGHLY RECOMEND IT. Share this post Link to post Share on other sites
