CRD 9 Posted September 14, 2009 Hi, I have question I hope some of you can answer. I currently have a Pcut cutter with laserpoint and with SignCut Pro I can manually contour cut at reasonable tolerance up to A3 size. I have a request for an order to produce 200 A5 size decals that need to be contour cut a and also have a full X and Y crosspattern cut over the decal. It all are small decals in the end on one sheet. Now if I just do it all manual upto A4 size to be sure the x-y cross cuts are 100% OK it will take me 10 hours at least to cut the whole job. With www.customracingdecal.com as side kick job that means I do not see my wife for a few days. ;-( if I take the job. So I was looking into a plotter using automatic cross mark recognition. But I have some questions about that. If I have a 60 x 200 cm pre printed sheet that contains a number of A5 size decals can it contour and cross cut all by it self with 100% tolerance from start to finish. Time is then no problem anymore I have seen the leaflet, the 5000-60 it can do, but need to know from first hand from a user who really worked with this function in the real world. I also like to know how the reg marks should look like and how they need to be placed. regarding loss if effective prining aera. I use corel X4 and convert the printjob for my printshop to PSD file so this shoudl already contain the crossmarks. When the printed sheet is received I have to contour it. I will add a sample eps file of the A5 size decal I need to make 200 times. Your help would be appreciated and who knows a 5000-60 user soon. Regards, Paco Raap 1X cst green-white xceeed logo.svg 1X cst green-white xceeed logo.svg Share this post Link to post Share on other sites
