wwpro 1 Posted September 4, 2009 hi there Seems like a little bit confused here, maybe someone here can shed some light on this. I don't have a mug heat press yet, but I was wondering if you can press anything printed, let say inkjet or laser, or it has to be sublimation inks, special paper and special mug ? Thanks in advance Share this post Link to post Share on other sites
BannerJohn 1,324 Posted September 5, 2009 there is an inkjet paper that comes in white and clear, that you can print on. IT is waterproof and has adhesive backing. I have used it and it works. It will fade in direct sunlight as most inks will, but after MANY washings of the mug I did, the colors stayed and never ran. Ideal solution if you just want to do a limited number,and no press required. http://cgi.ebay.com/INKJET-Waterproof-Adhesive-Decal-Paper-5-Sheets-WHITE_W0QQitemZ350245306412QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item518c3f402c&_trksid=p3286.c0.m14 Share this post Link to post Share on other sites
wwpro 1 Posted September 5, 2009 Thanks John, I asked this out of curiosity only, not that I'm interested, but is always good to clarify any doubts Share this post Link to post Share on other sites
svsignworks 0 Posted September 9, 2009 Ink sublimation is the only way I know that you can get a fade free print or picture on a mug or whatever you transfer too. Sublimation products do have a special coating to transfer ink to.Its a great way to start a business we make good money on promotional items and such.hope this helps some........ Dan svsignworks Share this post Link to post Share on other sites
wwpro 1 Posted September 9, 2009 Thanks Dan, I was (and still are) confused about what's to be done with the mug heat press. Share this post Link to post Share on other sites
