captonzoom 2 Posted September 2, 2009 Based on recommendations, I Bought Flexi Starter 8.6v2. I am trying to make a test cut, my name. 2"x4" it cuts in reverse even though it is not in "mirror" mode on the screen and when it gets to the "A" in my name, the cutter stops and says "cutting"........ I have a Copam 2500 I have no more hair left to deal with this. any help would be very appreciated. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 2, 2009 can you post a screen shot/picture of your screen design ready to go to cut, and also in production manager. Share this post Link to post Share on other sites
captonzoom 2 Posted September 2, 2009 Ok, will do when I get home. Share this post Link to post Share on other sites
captonzoom 2 Posted September 2, 2009 scott, did that, no go. Share this post Link to post Share on other sites
CyberSultan 6 Posted September 3, 2009 What is Com7 associated with? Serial cable or usb? I only use serial connection to my Copam. The default Copam driver that comes with Flexi causes that exact behavior you referred to. So if using USB...maybe there is something else that needs to be configured in the driver settings. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 3, 2009 What is Com7 associated with? Serial cable or usb? I only use serial connection to my Copam. The default Copam driver that comes with Flexit causes that exact behavior you referred to. So if using USB...maybe there is something else that needs to be configured in the driver settings. I found this info on another thread..... try these two different drivers, see if they help you. And yes I know they are different machines that what you are using, but other people with Flexi and Copams are using them and they work great for them. DGI OM-60 driver Graphtec CE1000-60 drivers http://forum.uscutter.com/index.php/topic,17558.msg140968.html#msg140968 http://forum.uscutter.com/index.php/topic,237.0.html Share this post Link to post Share on other sites
mudeater18 6 Posted September 3, 2009 Not sure if this is all of your problem, but wanted to make sure you know this. In Production Manager the button in the left lower corn that looks like a man, changes the orientation of the cut. Share this post Link to post Share on other sites
captonzoom 2 Posted September 3, 2009 Not sure if this is all of your problem, but wanted to make sure you know this. In Production Manager the button in the left lower corn that looks like a man, changes the orientation of the cut. Hi, I know, I figured that out. But, even listed like the way you have it, it cuts it in mirror even though mirror is not selected. Share this post Link to post Share on other sites
