jmonica 0 Posted August 13, 2009 I've purchased two batches of blades for my PCUT ct630 and so far both of them have been the wrong size even though they were sold as being for the CT630. The ones I am receiving ar thincker than the one that is in the machines blade holder now. I asked USCUTTER sales and they said that my machine might be older and and take an older size of PCUT blade that is narrower, but the email just said we don't have any for sale on our website. To be honest I didn't really care for the tone of this sales persons email from USCUTTER. It was short almost like he couldn't be bothered with me and my dilemna. No punctuation, no hello, no thank you, nothing. Just "we don't have them on our website" Could you spare the info? I've placed many orders with them and I don't think I should be treated like that but oh well. There are many other places to buy stuff who have employees that are willing to help and who are courteous. Ok getting back on track... I was really hoping that someone here might have had this problem in the past and/or may have found a supplier for the older style (smaller diameter) blades or found a suitable replacement blade that will work in it's place even though the ones that work may not be made specifically for the PCUT CT630? Thanks in advance for any help at all! Kind Regards Jim Share this post Link to post Share on other sites
BannerJohn 1,324 Posted August 13, 2009 the pcut that USC sells now uses a Roland blade holder. If yours has the old Pcut holder you will need to buy actual pcut blades. If you have the Roland holder, you need roland blades. You can have a look here: http://cgi.ebay.com/Roland-Cutting-plotter-vinyl-cutter-knife-Blade-Holder_W0QQitemZ160355086019QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2555e86ec3&_trksid=p3911.c0.m14 and here: http://cgi.ebay.com/Blade-Holder-for-Pcut-Cutting-plotter-vinyl-cutter_W0QQitemZ160355087091QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2555e872f3&_trksid=p3911.c0.m14 see which holder looks like yours. The same people have blades for both. I have dealt with them before,and always had in less than 2 weeks from Hong Kong. In the long run it might pay you to buy a roland holder.The Roland blades are more common and cheaper 1 Share this post Link to post Share on other sites
jmonica 0 Posted August 14, 2009 Thanks BannerJohn for the help! I really appreciate your time. I'm off to eBay to get the right blades (Thanks to you!). Have a great weekend! Regards Share this post Link to post Share on other sites
BannerJohn 1,324 Posted August 14, 2009 I do my best. Hope all works out for you. Share this post Link to post Share on other sites
jgreen 1 Posted August 27, 2009 If you can't find any on ebay. Clean Cut blades makes the old pcut blades. As a matter of fact they're probably the best blade maker out there. 1 Share this post Link to post Share on other sites
James@Infiniti 0 Posted September 12, 2009 just wondering if it is possible to convert the old style pcut blade holder to the new style roland blade holder? or is it loads of work for no real gain. Share this post Link to post Share on other sites
vicstransam 0 Posted September 20, 2011 I have found that the original Cricut blades will fit in my holder (Roland style I believe). Available at Wally world. Share this post Link to post Share on other sites
tbirddmnd 1 Posted June 13, 2012 Sorry to bump up an older thread but I'm going to agree with vicstransam - I'm awaiting new blades from online but I need to cut some stuff NOW. I was searching through the forum and wanted to find out the solution to problems I was having with my cutting. Turns out I have a bad dull blade - my last one. I went to a local crafts store in the Detroit area (Michael's) and found that they had Cricut accessories, specifically a 2-pack of replacement blades for $9.99 - they fit my original PCut CTN-630 holder just like the original PCut blades, virtually the same length and thickness. I just cut something with it and it works perfectly. Once my new 60 degree Roland blades arrive I'm going to use those and use these Cricut blades as back-ups. In a pinch they work excellent so if there are those looking for blades give these a try! On the back of the package on the bottom left the item number is 290002 "Cricut Tool Replacement Blades" and the UPC code is 093573840029, pictured below. They appear to be made by Provo Craft. Just wanted to provide a solution for folks looking for temp or replacement blades quickly. 1 Share this post Link to post Share on other sites
Acrylic Conceptions 5 Posted February 28, 2013 So I just put the Cricut blade in. I'm trying to adjust the offset but I'm not getting any luck. My corners are coming out wrong. I'm at .59 offset right now. My corners have a little kick on them. I was at a .25 offset with my previous blade. Not sure where it was from, maybe Randy (MrMopar) can chime in. I'm wanting to know what people are using for offset when using this blade in a pcut 24" machine. I've tired lots of different combinations from 0 - .90 and my best cuts are right around .5 - .60 but not right. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 28, 2013 too much offset - go the other way Share this post Link to post Share on other sites
Acrylic Conceptions 5 Posted February 28, 2013 I can never get to Good. I've seen too high and too low. I'm trying to get the pictures off my phone to post. Share this post Link to post Share on other sites
Acrylic Conceptions 5 Posted February 28, 2013 the 1st photo with the little kick out seems to be the best I can get it. I know the 2nd photo is too high. I even tried negative offset and no luck. My blade holder is clean. I have the blade depth adjusted correctly. My pressure is at 120 but from what I'm reading, that's probably not the issue. I did a test cut of "Datsun" in a really curvy font and its not bad, there are still a couple kick outs. The test cuts I'm doing were on a rectangle and then I switched to a 1x1 square. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 28, 2013 1st photo actually just shows the error of when the blade starts and stops - it must be drug a little bit to turn it - it is a drag knife type of cutter so there will be this kind of error when starting and stopping - again it is more pronounced on the value cutters Share this post Link to post Share on other sites
Acrylic Conceptions 5 Posted February 28, 2013 it didn't do this before. I was cutting some foil vinyl and I think I broke the tip of my old blade so I put this cricut blade it. Maybe I need to just get the roland ones. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 28, 2013 cricut actually uses a chinese roland blade Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 28, 2013 try a little less blade also to see if that helps 1 Share this post Link to post Share on other sites
Acrylic Conceptions 5 Posted February 28, 2013 I had to adjust the blade out more actually. But still same issue. Share this post Link to post Share on other sites
