ddakin 0 Posted August 11, 2009 Hi guys. I'm in a jam here. I have a section of curved text I need to cut. I typed the text in an illustrator text box and then used the arc tool to curve it. Unfortuantely when I send it to cut, Cutting Master only sees it as a straight line of text. HELP PLEASE! I need to cut this right away. Any help would be great. Thanks Dan Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 11, 2009 Hi guys. I'm in a jam here. I have a section of curved text I need to cut. I typed the text in an illustrator text box and then used the arc tool to curve it. Unfortuantely when I send it to cut, Cutting Master only sees it as a straight line of text. HELP PLEASE! I need to cut this right away. Any help would be great. Thanks Dan maybe try SAVE AS> and then import the design into your cutting software. Just a thought. Share this post Link to post Share on other sites
Renegade 2 Posted August 13, 2009 Have you converted it to curves, welded it, & looked at it in wireframe view? Share this post Link to post Share on other sites
joelmarley 0 Posted August 13, 2009 Select your text, then select objects, then select expand. This will turn it into a path. Then it should cut. Joel Share this post Link to post Share on other sites
