WORTHAM16 0 Posted July 24, 2009 trying to get pcut running. just recieved it and i can't get the usb comm's to match. comp says comm11 and sb only goes up to 8. any help would be great. Share this post Link to post Share on other sites
bmastiff 0 Posted July 24, 2009 you need to change comm port to different port in device manager Share this post Link to post Share on other sites
WORTHAM16 0 Posted July 24, 2009 NOT SURE IF AM DOING IT RIGHT TRIED COMM 1 AND COMM 2 STILL DIDN'T WORK Share this post Link to post Share on other sites
WORTHAM16 0 Posted July 24, 2009 somehow got it to work thanks for the reply :) Share this post Link to post Share on other sites
CRD 9 Posted July 25, 2009 In such a case. Remove all USB device fromt he PC. Put the USB cable to the cutter in a free USB slot and check in the hardware manager which port is validated. If your program is limited to a maximum number of 8 you have to try and error to solve that untill a port lower as 8 is detected. SOme pc's have more then 6 USb ports onboard!!!!! Comm1 and Comm2 are dedicted seriel ports which wich can not be used for USB serial communication. Paco Share this post Link to post Share on other sites
