snlsd 1 Posted June 28, 2009 I'm doing two of these windows. Graphic size is 75" wide by 35" tall. Just curious what you would charge for both windows installed. Thanks in advance. Share this post Link to post Share on other sites
john! 1 Posted June 29, 2009 $337.50 per window if each was 75x35" I'd probably do both for $500 though if they got them done the same time Share this post Link to post Share on other sites
midwaste 4 Posted June 29, 2009 How did you come up with that number, if you don't mind, John? What vinyl is that quote for? Share this post Link to post Share on other sites
john! 1 Posted June 30, 2009 How did you come up with that number, if you don't mind, John? What vinyl is that quote for? Oops, i see a mistake in my quote but this is how i do it The way i quote large vinyls are psf 6.25'x3'=18.75' per window 18.75'x$15psf for 3 color= $281.25 I like to charge 25% per extra color Share this post Link to post Share on other sites
midwaste 4 Posted June 30, 2009 So, bout $9 for single color, $12-13 for 2 color and $15 for 3? Installed, right? Sounds good to me. Thanks! Share this post Link to post Share on other sites
john! 1 Posted July 1, 2009 $10 single $12.50 double $15 triple color Now on vehicle lettering i usually add all that plus a install rate and a design rate since the job is smaller though Share this post Link to post Share on other sites
