Dsigns4U 0 Posted June 17, 2009 I have a slight problem. I have a logo to make that is a bit bigger than my cutter. What option in Signblazer would allow me to cut the logo into smaller portions before I cut it out of the cutter. Has anyone ran into this and do you have a simple solution I've just overlooked? Thanks for the help. Share this post Link to post Share on other sites
Guest round2racing Posted June 17, 2009 If you have set up your workspace as the actual size and you go into setup on your cutting screen and put in your actual vinyl size, it will tile it for you. Then, when you select cut, you have an option to select which tile to cut. I did this for my race trailer and made it in to pieces. The left tile was smaller than the right tile, so I adjusted my vinyl size so that the decal was cut directly in half. For example, my decal was 36in wide. Instead of cutting a 24 wide and a 12 wide, I set my vinyl size at 18in wide and it cut my decal directly down the middle. Hope this helps. Share this post Link to post Share on other sites
pshawny 410 Posted April 17, 2014 What size is your cutter? What size is the design? Can you attach a picture? Signblazer has a feature called tiling that will split up the decal into as many pieces as needed. There are a few other ways to do it too. Share this post Link to post Share on other sites
Jay2703 704 Posted April 17, 2014 Really? This is almost 5 years old. 1 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted April 17, 2014 Really? This is almost 5 years old. Ha! Ha! Time Warp! 1 Share this post Link to post Share on other sites
pshawny 410 Posted April 17, 2014 I didn't notice the date either. It looks like the post before slice&dice was removed. It was a bunch of jibbery jabber nonsense. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 17, 2014 yeh - he got banned - Share this post Link to post Share on other sites
