Twister 0 Posted June 15, 2009 How do i re-install usb port, there is none showing up on my computer what so ever. It may be the cord not showin up, but under the device manager, nothin shows up for the USB port. Ihave no idea what to do.. I run a racing sticker business and this has to be fixed to make stickers. Any on have any idea? Cause it won't cut, it says can't find output device Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 15, 2009 try a different usb cable,, maybe it is broken and can not be recognized.. go thru this, make sure your signware is set to the correct comm http://forum.uscutter.com/index.php/topic,1602.0.html Share this post Link to post Share on other sites
Twister 0 Posted June 15, 2009 That doesn't help me any. Beccause we lost our USB port thing and it doesn't show up on the computer at all anywhere. we just recently turned our lab top in and got a Window's VISTA home, hp pavlion (special edition) desk top. We figured that it was the computer it self. but this doesn't show up a usb port either. We have 2 usb ports. but i will try and go buy a new one to see if that's the prob. Share this post Link to post Share on other sites
Twister 0 Posted June 15, 2009 In signblazers program, we use to have usb serial port. Now that is no longer there. All we have is a summa usb port. the computer guy said this is the problem. Why isn't usb serial port in the program? We re-installed disc, still isn't there.. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 15, 2009 if the USB cable is broken,or faulty it will not recognize it.. Also do you have your cutter turned on when you are looking in the device manager, plugging and unplugging? It should be....just trying to get the small things out of the way first, before looking at larger problems.. gotta start there.. Share this post Link to post Share on other sites
Twister 0 Posted June 15, 2009 In the signblazer program, why is the usb serial port not there anymore.. Under set ups, in the program, there is no usb port other than summa. Why? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 15, 2009 I do not use Sign Blazer, so I am familar with the set up on the program... what kind of vinyl cutter do you have? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 15, 2009 I just downloaded Signblazer from their EBAY site and started to go thru a setup... I got to the picture where it shows serial cable USB etc.. and on the list it does show it has just USB right under LPT4,,,,picture included below ...maybe you should uninstall and reinstall the SignBlazer software. .. http://cgi.ebay.com/NEW-USCutter-24-25-Vinyl-Cutter-Cutting-Plotter-w-USB_W0QQitemZ270408263162QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef596a5fa&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50 Share this post Link to post Share on other sites
Twister 0 Posted June 15, 2009 Should we go do a serial port at like radio shack or somethign? or just buy a new usb cord. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 15, 2009 I just downloaded Signblazer from their EBAY site and started to go thru a setup... I got to the picture where it shows serial cable USB etc.. and on the list it does show it has just USB right under LPT4,,,,picture included below ...maybe you should uninstall and reinstall the SignBlazer software. .. http://cgi.ebay.com/NEW-USCutter-24-25-Vinyl-Cutter-Cutting-Plotter-w-USB_W0QQitemZ270408263162QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef596a5fa&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50 did you read this first?... you can get a USB cable at Walmart etc.. Share this post Link to post Share on other sites
Twister 0 Posted June 15, 2009 I done tried that but ill do it again.. I reinstalled it twice. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 15, 2009 where are you downloading it from? try the download from EBAY site.. that is where I got it.. Where it says 5 reasons to Buy from US Cutter... DOWNLOAD the SOFTWARE from this site http://cgi.ebay.com/NEW-USCutter-24-25-Vinyl-Cutter-Cutting-Plotter-w-USB_W0QQitemZ270408263162QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef596a5fa&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50 Share this post Link to post Share on other sites
Twister 0 Posted June 15, 2009 Well when we bough the US Mh721 cutter, the signblazer soft ware came with it. So that's where we used it. But ill uninstall this & try ebay Share this post Link to post Share on other sites
coloradokev 0 Posted June 17, 2009 Hey Twister, Does any other device (mouse, thumb drive, inkjet printer) work from your computer's USB port(s)? You'll want to confirm port viability using something else if you can. Apart from that, have you no DB-9 serial port on your desktop? That would be a good option to use. - K Share this post Link to post Share on other sites
ViciousVinyl 0 Posted July 1, 2009 Did you install the seperate USB driver that is available for download? If not you can download the FTDI drivers here: http://support.uscutter.com/index.php?_m=downloads&_a=view Hope this helps! Share this post Link to post Share on other sites
