Aromo
SignCut draw an unnecessary rectangle at the enf of work
Hi,
I have a problem with SignCut and don't find the solution: if I send something from SignCut Pro to the plotter, it cuts the objects well, but after finishing it cuts a rectangle around the work. The problem is, that this is too close to the cutted work and not easy to handle it. How I can deny in the software not do the final rectangle cut around the objects? Or How I can set a higher distance between the cutted objects and the rectangle? Cutting preview did not showed this rectangle, but if I see the main window of SignCut Pro, a blue rectangle (that I though the end of the imported object) is always around the object. I imported the work from ai and no rectangle was around the objects...
Thanks for help!
That square is your weeding frame.  When you hit cut, check the box that pops up.  3rd line down is "Weeding Frame".  Leave it checked, but increase the size thats in the box to the far right of it.  This will increase the size of the frame around your artwork.
JC
