busterrolland
usb serial port not in list
Can anyone advise me on this problem?
I'm running a G3 mac with OS X 10.2.8, a Refine MH365 cutter, and Flexistarter 7.5 v 5 mac design software, with a KeySpan USB to serial converter to the cutter.
When I setup the cutter in Flexi, everything is fine except the KeySpan port name dosen't show up in the Port dropdown menu.  And... as you might guess, no cutting is accomplished.
I have reinstalled everything (flexi, and keyspan) --- no help.  The port shows up in KeySpans assistant just as it is supposed to.
What's the trick/tip/right thing to do here?
Seems as though Flexi is not picking up the driver from the Keyspan. Have you tried the software that came with the cutter? Will it communicate through SignCut? Might just be an issue with Flexi.
Thanks for the info.  I'll give it a try.
I purchased the Flexi software SPECIFICALLY because it was Mac/OS X compatible.
I will raise this question with them also.
Again... Thanks
Buster
