Krolla
My Pcut fan wont turn on anymore
Here we go this is the right section Anyways...
So ive had the plotter for about a month maybe a little longer. The fan has always turned on when i turned the plotter on except once. But now it donsnt turn on very much asn when it does it starts out at full speed but will slow down.
I just moved your other thread here to the pcut support forum, so this one is locked.
This biscuit type fan is easily replaceable... You can purchase this type of fan in any Radio Shack and you do not even need to reference the manufacturer. However you should bring in your original fan just to match it up as well as possible. You want at least the same CFM's and if you can get one with a bit more silent operation to cut down on noise levels.
Hope this helped...
-Brandon
"I LOVE TO CUT"
Guest
This topic is now closed to further replies.
