So when i 1st got the pcut about a month ago the fan would always turn on when i turned the plotter on except for once. But recently it only turns on sometimes and sometimes it slows down. Is this normal?
Guest stunad, jr.
does it perform the same way it did before you discovered the fan not running?
like does it still cut and everything? Yeah. It hasent overheated either but i uselly only have it on for 20-30min tops
Guest stunad, jr.
If that's the case, I wouldn't worry about it.
The fan is an accessory to assist the pinch rollers.
If it is cutting with good results, I would be happy.
I see no real need for the fan anyway...
Think of the money you are saving on energy  :thumbsup:
:thumbsup:
No... all the fan does on the pcut is pull the vinyl material onto the cutter, as Stu said, to assist the pinch rollers.
Is the cutter within it's warranty? I believe the pcut has a 6 month warranty if purchased from USC's ebay store, or a full 1 year warranty if purchased directly from USCutter.
