btfischer 0 Posted August 27, 2007 Has anyone tried or does anyone know a way to remove heat transfer vinyl. I am using thermoflex plus (which is great!), but I have a customer who needs to make a change. This was a team name to a uniform. Any suggestions or ideas before I experiement? I have never, luckily, needed to do this before. Thanks so much for any suggestions! Share this post Link to post Share on other sites
Guest fivestar Posted August 27, 2007 TJ I have been able to use a heatgun to remove it but it leaves a little bit of glue behind so if it is going to be covered back up you will be fine. Share this post Link to post Share on other sites
btfischer 0 Posted August 28, 2007 Thank you, it worked great! Share this post Link to post Share on other sites
UpNorthPromo 3 Posted October 9, 2007 I have used acetone and it works great. I put it in a spray bottle an spray the inside of the shirt. It will come off easily. Share this post Link to post Share on other sites
