SandyM114 0 Posted March 31, 2009 I tried to cut my first tshirt vinyl design tonight. I did mirror my image, so did that part right, but after the cutting was finished, there was nothing there. Cut it 4 separate times and nothing shows up. Do you change the blade depth or the pressure to cut this vinyl? I've messed with both with no luck. What's going on?Anyone? Sandy Also, I'm pretty sure I have siser easy weed in white. It's not on a roll, so its hard to decide which is the right and wrong side. The glossy side seems like it's the clear backing, sound right? Help! I've got 4 band shirts for my grandson's band and he needs them Wednesday night if I can get them done. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 31, 2009 Sandy - You are correct that the shinny side is the backing - cut some tonight - after you cut the white Siser you cannot see the cuts but when you start peeling it you will find the edges. I have read several things from wiping it after cutting to pouncing with blue chalk line chalk and wiping to make it easier to see. The white is by far the worse Share this post Link to post Share on other sites
SandyM114 0 Posted March 31, 2009 I've reads everything I can on this topic, but I think my blade is the problem. I can't see it touching the vinyl as it cuts, there are no lines cut when it's finished cutting.Sandy Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 31, 2009 after cutting it doesn't look like it's cut - I would try a small peice Share this post Link to post Share on other sites
SandyM114 0 Posted March 31, 2009 I cut the same piece of vinyl 4 separate times, there were no cuts anywhere either time. I tried to weed, and there was no cuts at all. Should I change the blade depth so the blade sticks out more? Share this post Link to post Share on other sites
Guest fivestar Posted March 31, 2009 Sand you normally don't have to do that, but since you're saying there is no marks on the vinyl then yes I would try extending the blade some. Share this post Link to post Share on other sites
gagray1 0 Posted March 31, 2009 What vinyl are you using? I have to change my force from 70 to 120 to it cut some of the vinyl. I have a cheat sheet so I will remember. I don't change my blade depth, just the force and I always perform a "test cut" before cutting the project. In my cut program (Sign Cut X2) I have the option of the test cut. It cuts two small squares on inside the other, then I can check for weedability. Share this post Link to post Share on other sites
sarconastic 29 Posted March 31, 2009 I cut some Siser easyweed white with mine a few weeks ago. I was using a pressure setting of 110 to 120, I didn't change my blade depth, still set at half a credit card. It is hard to see the line on white though that is for sure. Share this post Link to post Share on other sites
Renegade 2 Posted March 31, 2009 I agree with not changing your blade depth for heat press vinyl as its very thin and it shouldn't be necessary. Pressure is where you need to look if you have already been cutting properly on sign vinyl. Also, you might need to wipe down your vinyl after its cut to help see the cut marks as some are very hard to see when there is dust or oxidation on the surface. Share this post Link to post Share on other sites
FutureSgtsWife 0 Posted March 31, 2009 I have the laserpoint.... when I cut regular vinyl, I use 117 pressure. When I cut heat-applied vinyl for tshirts, I up it to 141..... Don't change your blade depth - change the pressure on the cutter. Share this post Link to post Share on other sites
SandyM114 0 Posted April 1, 2009 Than ks very much for the information. I was finally able to get it cut. My blade wasn't sticking out of the holder at all, so I really wasn't getting any cuts. I upped the pressure to 140 and cut almost through the backing in places. I'll have to really lower it next time. I'll post a pic tomorrow after pressing the shirts.Thanks! Sandy Share this post Link to post Share on other sites
Renegade 2 Posted April 1, 2009 There are plenty of good guides for setting blade depth around here. I would recommend for something quick and easy to just put the blade all the way in and manually test it on a scrap piece of vinyl. Adjust the blade out about a 1/4 turn and then test over and over till you get it so you have just enough blade sticking out to cut through the vinyl and not the backing. Then when you put it back in your cutter you may be a bit short depending on your pressure and cutter in general. Then you can do some small adjustments if needed to get it just right. Once I get the depth set right I don't mess with anything but pressure unless I'm doing some kind of mask or something thicker. Share this post Link to post Share on other sites
