Joezeppii 0 Posted March 30, 2009 Does anybody know if it possible to cut directly from Corel 10? Thanks Share this post Link to post Share on other sites
Fbomb 0 Posted March 30, 2009 No...you can copy/paste from Corel to SB. But I've had problems doing that (CDR12). I simply export to EPS in a Plotter folder (then a subfolder). This is the best option anyway (since you can't cut from CDR10). What program are you cutting with? Share this post Link to post Share on other sites
Joezeppii 0 Posted March 30, 2009 We are using flexi 8.1 to rip/ print then cut. I was wanting to know what I need to use to just cut vinyl lettering. Should I use the sign blazer that came with my cutter? If so, is there a phone number I could call you to walk me through the steps? Thanks Share this post Link to post Share on other sites
Guest fivestar Posted March 31, 2009 No just use Flexi to cut. Set up your cutter just as you did your printer in Flexi. Share this post Link to post Share on other sites
Joezeppii 0 Posted April 1, 2009 The problem is that my son set it up and I don't know how he did it and he is unavailable to help. Any idea on how to help me set it up? Thanks Share this post Link to post Share on other sites
JoeBlow 5 Posted April 1, 2009 There's a few add-on programs that allow you to cut directly from Corel such as "CoCut" http://www.cocut.com/index.dml?unten=produkte/CoCut-Professional-e.htm&von=html Share this post Link to post Share on other sites
