sarconastic 29 Posted March 27, 2009 I was sitting here trying to figure up my expenses on a few decals I just made, and thought why not just make a spread sheet that does it for me. So I sat down and figured out the formulas and here ya go. I have attached the Excel file here. I was going to get a little more advanced, and I am up for suggestions. It will let you put the Name of the vinyl, your Supplier, the width and length, then it calculates your cost per square yard, foot and inch. Then at the end you can put in a length and width for a sign or decal and the number of color layers and with let you know the cost per decal/sign. It's basically a running list of your materials with some calculations in it. So you get a new roll, you put it in the sheet while you have the invoice handy and then when you need to know what a project it going to cost you enter the numbers. Kind of like a mini Inventory. If you have more rolls that the sheet I sent uses, just copy a row and paste it back in below the bottom. It should copy the formulas etc into the new row. Let me know what you think. This was done in Excel 2000, but it should open using OpenOffice spreadsheet too if you have it. ***EDIT: Updated this one to the new version, Roll Vinyl Calculator 2.zip Roll Vinyl Calculator 2.zip 4 Share this post Link to post Share on other sites
Guest fivestar Posted March 27, 2009 Thanks alot, I will give 'er a go and see how she performs. Share this post Link to post Share on other sites
SandyM114 0 Posted March 27, 2009 Hey, thanks! I can use this! Sandy Share this post Link to post Share on other sites
jfought 120 Posted March 28, 2009 this is for me and the other 20 ppl that did not give thanks for all the work that you put into this. Thank You 1 Share this post Link to post Share on other sites
firemalt 10 Posted March 28, 2009 Thanks for sharing, and taking the time to create the form... I'll give it a shot in the morning. Share this post Link to post Share on other sites
firefighter1138 1 Posted March 28, 2009 Excellent, works great. Had to copy the formula down in last colom. I like it, gives you a great idea of your cost of materials without using your brain. I've already got plent of vinyl and all my application tapes put in. Thank you for takong the time to do this and even bigger thanks for posting it. Jim Share this post Link to post Share on other sites
wdcisco 0 Posted March 28, 2009 thanks will check it out! Share this post Link to post Share on other sites
sarconastic 29 Posted March 28, 2009 Thanks everyone for the support. I figure this is one way I can give back a little bit. I filled out that last column that I forgot, and also added a check to make sure it wouldn't error out when there were no totals. I added a Sum at the bottom so you could add a couple vinyls together for a bid or whatever. I didn't change anything on the left side, so if you already put all your stuff into the old one, just Copy and paste it into the fixed one. Hopefully it helps someone. Roll Vinyl Calculator 2.zip Roll Vinyl Calculator 2.zip 1 Share this post Link to post Share on other sites
kmerting 0 Posted March 28, 2009 Thanks for posting this! Share this post Link to post Share on other sites
Cre8tiveCutter 7 Posted March 28, 2009 Thanx for this I needed something like this! Renee Share this post Link to post Share on other sites
john! 1 Posted March 28, 2009 lol where was this about a year ago when i was doing manual calcs to find this info out? lol Share this post Link to post Share on other sites
jfought 120 Posted March 28, 2009 would it be possible to have it total you app tape and vinyl for a job? Share this post Link to post Share on other sites
nonabelle 5 Posted March 28, 2009 thanks, will give it a try. thanks for u taking the time and sharing ur program with us. Share this post Link to post Share on other sites
Johnnyboy7444 0 Posted March 28, 2009 wow good work that will be very helpful but like said before is it possible to calc in the cost of app tape aswell Share this post Link to post Share on other sites
joshlindt 2 Posted March 28, 2009 would it be possible to have it total you app tape and vinyl for a job? i just added the tape in on one of the lines just as it was vinyl 1 Share this post Link to post Share on other sites
Jeffrey06 2 Posted March 28, 2009 I made one myself when I first bought my cutter. It's not as clean as yours. And mine prices a little higher. I'm getting a total of about $0.55 a Square Foot. That;s with Vinyl roll costing about $26.00. Here is mine, it's ruff, but it works for me. pricing calcuator.zip pricing calcuator.zip 1 Share this post Link to post Share on other sites
DanielB 0 Posted March 28, 2009 Thanks a lot for sharing your work. We all really appreciate it!!! Share this post Link to post Share on other sites
sarconastic 29 Posted March 29, 2009 Johhnyboy, Just put your roll of app tape in just like a roll of vinyl, it will still calculate. Example a 24" wide roll of Rtape 4076-RLA from Uscutter is 71.02 a roll, enter those just like a roll of vinyl. All this thing does is take the Length and width of the vinyl roll, convert it to sq inches then divide by the cost per roll. then when you put in the dimension of your vinyl and or tape it multiplies the square inches by the cost per square inch and then totals at the right. I also added a sum to the 2nd version that will total any entries you have figure on the right. Jeffery, I thought about adding a summing job calculator, and I might get a little wild one of these nights and and create a separate workbook that is more form like, that way people will be able to keep a seperate inventory and just check off which material they are using etc. If i get that serious about it, we're gonna have to talk "Vinylware" license..'Free to try, Send Sarc a chunk of vinyl to Continue using.' I actually enjoy creating tools that help make the work easier. Share this post Link to post Share on other sites
Jeffrey06 2 Posted March 29, 2009 Johhnyboy, Just put your roll of app tape in just like a roll of vinyl, it will still calculate. Example a 24" wide roll of Rtape 4076-RLA from Uscutter is 71.02 a roll, enter those just like a roll of vinyl. All this thing does is take the Length and width of the vinyl roll, convert it to sq inches then divide by the cost per roll. then when you put in the dimension of your vinyl and or tape it multiplies the square inches by the cost per square inch and then totals at the right. I also added a sum to the 2nd version that will total any entries you have figure on the right. Jeffery, I thought about adding a summing job calculator, and I might get a little wild one of these nights and and create a separate workbook that is more form like, that way people will be able to keep a seperate inventory and just check off which material they are using etc. If i get that serious about it, we're gonna have to talk "Vinylware" license..'Free to try, Send Sarc a chunk of vinyl to Continue using.' I actually enjoy creating tools that help make the work easier. Yep. It makes it a ton easier when you sitting there pricing a job, and trying to figure out how much you have in materials. I do have the version with the sums, but it isn't 100% yet. When I complete it I'll update this thread. I'm also looking into a bases of using markup %'s for the user to select, then show the figured advertised price. Share this post Link to post Share on other sites
Alien 11 Posted March 29, 2009 THX us newbies need all the help we can get 2 Share this post Link to post Share on other sites
tshirtn00b 12 Posted April 1, 2009 bad ass. Thanks! Share this post Link to post Share on other sites
VinylLPCP 0 Posted April 1, 2009 Thanks for doing the work and sharing with everyonr. Mike Share this post Link to post Share on other sites
alhjc6 0 Posted April 1, 2009 Sweet!!! Thanks a bunch! Share this post Link to post Share on other sites
