Socal 0 Posted August 9, 2007 I installed driver USB but Vista dont show COM ports ?? driver installed can see in System hardware as usb converter but in Signblazer no mater what I do in setup cutter Nothing works HELP ! thx Share this post Link to post Share on other sites
stormy 5 Posted August 9, 2007 Make sure you have the USB port set as a COM port. Go to properties I think for the USB converter. Then set it as same COM port in Signcut. I just set mine up a week or so ago but I cant even find where it says USB Converter in device manager now. Share this post Link to post Share on other sites
kenimes 42 Posted August 9, 2007 Also make sure your Baud rate in SignBlazer under Comm Settings matches the Baud rate on the cutter itself. For the PCut, just press the online button, then use the mode button to get to the baud. Share this post Link to post Share on other sites
Socal 0 Posted August 9, 2007 OK found problem Had to shut down Internet connection - so I could have CD drivers LOad OK new Problem - Software locks in Cutting Mode after I do first project have to reboot computer then can start new project but have to reboot to start again Got any Idea's Share this post Link to post Share on other sites
Socal 0 Posted August 10, 2007 MOre on this problem when cutter second time Cutting tile not responding Sending File output to cutter Now the whole program set there as I type this Post computer works fine but will have to reboot now and start Signcut again to cut my checker board pattern ?? Share this post Link to post Share on other sites
kenimes 42 Posted August 10, 2007 You can phone me and I can log on to your computer and do some troubleshooting. 866-789-2919 Share this post Link to post Share on other sites
