MarwanB
Shredding Vinyl... HELP!
Might be a blade depth issue. If it is a Refine cutter you might also check and make sure the carriage is on its tracks properly.
don't forget that every time you turn on the machine you should set the blade force.  it defaults to 100gm which is way to much for the average vinyl.
I noticed on my Pcut the vinyl can hit a lip on the front edge of the cutter. The vinyl would pop up and get shredded. I stuck some masking tape across this lip to make a smoother transition.
on my main cutter,I had that same problem when it first arrived. It seems that in shipping,the pannel that covers the front had shifted just a tiny bit. I just smacked it down with the palm of my hand,and no problems.
