GATOR 1 Posted August 6, 2007 this just started on 08/05/07 I take a design, select the plot tool that sends me to the production manager. and I get this message: "runtime error! ProgramC:ProgramFilesflexiSIGN-Pro7.5v2programapp2.exe abnormal program termination then when I click OK, it takes me to the Production manager, but when I hit "send" to make the cuts I get this message: "no set-up has been selected please select a setup" I have been having sooo much fun with this plotter. What have i done? Thanks in advance for all help G Share this post Link to post Share on other sites
BannerJohn 1,324 Posted August 6, 2007 sounds like that a file somewhere has been corrupted. First thing to do,is turn off computer,re-boot. Turn off cutter,turn it back on. If this doesn't work,go into the Flexi setup and try installing the cutter again. If this doesn't work,re-install Flexi. If,after all this...you still get the same error, go to the Flexi forums and beg for help. I have had,in the past,a program (not Flexi) just shut down when the memory on the computer was maxed out. Try closing everything you can before you try and cut. Share this post Link to post Share on other sites
GATOR 1 Posted August 7, 2007 thanks John. I just upgraded from 256 to to 768 on the memory. still going to go back and re-install my plotter, but the memory didnt help so far Share this post Link to post Share on other sites
GATOR 1 Posted August 7, 2007 hey Banner John, the re-install solved the porblem. Thanks for your help Share this post Link to post Share on other sites
