kolorkraze 0 Posted August 4, 2007 Hi, I have 50 signs due tomorrow morning. I've cut about 30 of them now the cutter freezes half way through. Anyone knows what's causing this? :- Share this post Link to post Share on other sites
Daniel T 0 Posted August 4, 2007 when everything goes haywire i just turn off the computer, reboot and re open the file and start again. sorry i can't be of any more help. just make sure that the carriage is still on the track and hopefully you will finish to meet your deadline. take care, daniel t Share this post Link to post Share on other sites
kenimes 42 Posted August 4, 2007 Which cutter, which cutting software, which connection method? Share this post Link to post Share on other sites
kolorkraze 0 Posted August 4, 2007 US Cutter MH721, sign cut x2, USB. Half way through the print it just stops and have to restart computer and cutter. Share this post Link to post Share on other sites
kenimes 42 Posted August 6, 2007 I would suggest another connection method, maybe Serial or Parallel. If you only have USB available, you might try lowering the buad rate on the cutter and in SignCut, you could also try to change COM ports in case there is a conflict. Share this post Link to post Share on other sites
