i just got my PCut and Can not figure out how to connect the plotter to the pc using the serial cord. Do I just plug it in and it should work or do i have to install something??? Please help asap I want to start playing!!!
I installed my software first then connected my PCut630 using the serial connector. When you start the SignBlazer software it will see the cutter.
Guest
You do not need drivers for the serial connection. Hook the cutter up to the computer with the serial connection and turn the machine on. Open SignBlazer Elements, click Cutter, click Setup, change the top drop down box to Creation PCut CTE630 HPGL, change the second drop down box to Blazer.Com1: Communications Port. You should be good to cut now.
