mac6986 93 Posted January 11, 2009 can you cut directly from cs4? Share this post Link to post Share on other sites
Robert H. Bigart 64 Posted January 11, 2009 I don't know why not. Bob Bigart Share this post Link to post Share on other sites
mac6986 93 Posted January 12, 2009 now im new to this so forgive me if these questions sound stupid but do i need to identify my cutter as a printer and just send my finished job to that selected printer? or is there some different things i need to do? Share this post Link to post Share on other sites
HrdCorHillbilly 0 Posted February 20, 2009 I'm not having any luck either. Bob, Is there a certain driver we need to cut with Illustrator? I'm dying to find another program to cut with. Signblazer has got to be one of the buggiest programs I have ever used. Thanks Share this post Link to post Share on other sites
DaveS 0 Posted February 20, 2009 Not from Illustrator itself, it's used only for designing. You can if you have Signcut x2 Dave Share this post Link to post Share on other sites
machina 0 Posted June 26, 2009 Sure, just print to the cutter and then the plotter control comes up and there you go. Also have plugin for Illustrator CS4 that uses Cutting Master dialog. All work perfectly. Running Graphtec CE5000-60 by the way. dr Share this post Link to post Share on other sites
hyptonic 0 Posted July 9, 2009 Sure, just print to the cutter and then the plotter control comes up and there you go. Also have plugin for Illustrator CS4 that uses Cutting Master dialog. All work perfectly. Running Graphtec CE5000-60 by the way. dr Cutting Master 2 works only for the Graphtec brand. You can download all the applications here. if you want just cutting master scroll to the bottom http://www.craftrobostore.com/craftrobodownloads.html Share this post Link to post Share on other sites
CRD 9 Posted August 13, 2009 From Illi or Corel which are only vector design programs you can only plot/cut directly by using something called a plugin. There are no plotter drivers if you are using a Pcut or Uscutter machine available. The plugin converts your vectors to a cutfile the cutter can use. Programs that do so are for instance I know off are Signcut and Cocut. Paco Share this post Link to post Share on other sites
