Guest TracMatt Posted January 8, 2009 I am using Flexi and I have an LP24. About every other time I cut the cutter cuts through the entire design diagonally and wastes all the vinyl in that cut. Anyone have any ideas why? Thanks, Tracee Share this post Link to post Share on other sites
Guest TracMatt Posted January 8, 2009 Yes. New one from computer store. Tracee Share this post Link to post Share on other sites
CyberSultan 6 Posted January 8, 2009 I've had this happen to me is when I used 24" vinyl on my Copam, serial connection, using SBE. Other combinations of vinyl size and software did not do that (SBE seemed to be the issue in my case). I use only Flexi to cut now and don't experience that issue with any vinyl sizes. Never did figure out what caused it to do that. Probably some setting or issue within the software. When using Flexi, does it do this with any size vinyl roll? Share this post Link to post Share on other sites
Guest TracMatt Posted January 8, 2009 Yes, any size. But intermittent, anotherwards if I cut out two now they would be okay, but then the next two it will do it. Cuts straight across the vinyl diagonally ruining the whole design. Only flexi, didn't do it with SBE but I had tons of other problems with SBE so I don't use it now. Tracee Share this post Link to post Share on other sites
CyberSultan 6 Posted January 8, 2009 Did it just start doing this Tracee? What driver are you using within Flexi? Share this post Link to post Share on other sites
Guest TracMatt Posted January 8, 2009 lol no I just finally got mad about it to tell you the truth. Been using Flexi for about 4 months now. CT-630 I think is what you are asking me about the driver? Thanks Cyber, Tracee Share this post Link to post Share on other sites
CyberSultan 6 Posted January 8, 2009 Ken or Levi, do you guys know if the CT-630 is the compatible Flexi setting for the LP24? I don't have an LP24 to test, but it could be some incompatibility there. Share this post Link to post Share on other sites
kenimes 42 Posted January 8, 2009 Yes, when i setup a LP with Flexi, I select the Creation PCut CT630 DMPL. Share this post Link to post Share on other sites
Guest TracMatt Posted January 8, 2009 So is it the USB? Has anyone else ever reported this problem before? Tracee Share this post Link to post Share on other sites
kenimes 42 Posted January 8, 2009 Yes, the most common setup configuration when I hear of this issue, is USB connections and laptops. Do you have the option to use the 9-pin Serial instead? Share this post Link to post Share on other sites
Guest TracMatt Posted January 8, 2009 Yes I believe so if I had a cable Guess I will have to go purchase one. Thanks for the help. I will try that and let yall know. Tracee Share this post Link to post Share on other sites
kenimes 42 Posted January 8, 2009 If the LP has a 9-pin Serial port on it, it should have come with a cable for that connection. Share this post Link to post Share on other sites
Guest TracMatt Posted January 8, 2009 Oh lord really? That was like 6 months ago lol. I'll look around though. Probably one of those things I had no idea what to use it for and stored it some place LOL. I'll look around for it. Then what do I changed my flexi options to? Tracee Share this post Link to post Share on other sites
kenimes 42 Posted January 8, 2009 Just unplug the USB cable, plug in the Serial cable, and set the port to COM1 in Flexi. Share this post Link to post Share on other sites
Guest TracMatt Posted January 8, 2009 Okay thanks will do. Tracee Share this post Link to post Share on other sites
Guest TracMatt Posted January 9, 2009 Well I found the cord and it did not work. Says can not open port no matter what I change the settings to. I always set them to match in both the software and the device manager and still nada. Back to the usb I guess for now. Tracee Share this post Link to post Share on other sites
kenimes 42 Posted January 9, 2009 Send me a PM with your phone number, and I will phone you to walk through configuring the Serial cable and port. Share this post Link to post Share on other sites
Guest TracMatt Posted January 12, 2009 Okay Ken will do when I'm not up to my knees in orders Thanks, Tracee Share this post Link to post Share on other sites
tnwalkinghorse 0 Posted February 9, 2009 Any results on this? I am getting the same symptoms. (line cutting through vinyl) Is serial connection suppose to be more reliable? Also, why does the cutter pause sometimes, as if it is going to lock up and then continue cutting. Is this the buffer filling up? Anyway, would love to hear the results on the line cutting issue. Thanks! -Matt Share this post Link to post Share on other sites
kenimes 42 Posted February 9, 2009 I do not remember if we got this resolved or not, but yes, the 9-pin Serial cable is much more stable, so use it if at all possible. Share this post Link to post Share on other sites
tnwalkinghorse 0 Posted February 10, 2009 Thanks! I will give the serial cable a try. -Matt Share this post Link to post Share on other sites
lueman 19 Posted May 17, 2009 I know It's a little late to post this, but it sounds like the software isn't sending a "pen up" instruction at end of design. Hope this helps someone one the future. Share this post Link to post Share on other sites
