Benr98 40 Posted January 1, 2009 I currently am cutting a square outline.....I had to cut it in 3 sections because of it's size...with the Copam it feeds forwards and backwards a number of times between cuts....after applying the application tape and trying to place it on the banner, I noticed that the thickness of the lines in each cut (3 of them) is not proportionate! one side is thinner then the other, and then the other side may be wider....I have to wonder could it be the software and NOT the cutter? Jenny Share this post Link to post Share on other sites
BannerJohn 1,324 Posted January 1, 2009 it could be that your tracking is just a bit off to. Share this post Link to post Share on other sites
Benr98 40 Posted January 1, 2009 Do you know how to check on tracking? the ONLY other time I had this issue, is for that large 4x8' plexi sign, remember? All other cuts have been great...but when I do a sign outline...I have this problem! :- Share this post Link to post Share on other sites
