stuart
creation pcut
hi
can anyone tell me which holder thr blade goes in (front hole or back hole) have had mine ib both and it doesent seem to make any difference
stu
Fire, I use mine in the front, and have had no trouble at all, is there a true difference or is the carrage set up so you may be able to incorp a laser pointing devise into the setup ?
From my understand... the front slot is for the pen attachment.
I haven't been wrong once this year!!! I promise! ;)
In the rear slot, the blade should directly over the gray cutting stripe? Correct?
I read somewhere that the front slot is if you want to cut all of the way through. Like for card stock.
I was thinking that was on the Refine... but it may be like that for both models.
That's where you want it to be... that gray strip is a "cutting strip" for the blade to move back and forth on, so just incase your blade cuts all the way through the material, it won't damage the blade.
damn, I learn something every day, lol  now maybe I will see if I can retro a laser in the front slot...  lol, thanks guys !
I thought of that but the slots overlap. It could not be a round laser.
Thanks for the replys so far.
if you dont ask questions you dont get answers.
Talking of which where would i get a pen from,remember i live in the u/k
stu  :D :D
Wasn't there a pen with your PCut when you bought it?
i got it second hand  and there was not one with it
stu  ;)
Guest
If you do not want to pay the shipping any pen would probably work alright. I read a post a little earlier where someone said they were using sharpies and that worked fine too. With a sharpie you aren't going to get much detail, that is just an example.
