randyb 1 Posted December 22, 2008 you know the box that signblazer cuts around each gaphic you cut.Which does make is nice for weeding but, i just cut a 88inch graphic and it cut the box and then the design went about 2 inches over the top of that box? Share this post Link to post Share on other sites
Jay2703 704 Posted December 22, 2008 Turn off your weeding options in the cut window if you do not want those to cut. Share this post Link to post Share on other sites
wasatchcars 0 Posted December 22, 2008 Turn off "weed all" and in set up select "Best Tracking" I find that best for long cuts Share this post Link to post Share on other sites
randyb 1 Posted December 22, 2008 Thanks guys, that helped ALOT. What does cutter direction mean, in the set up? Normal,clockwise or counter clockwise? Share this post Link to post Share on other sites
Guest Posted December 23, 2008 Thanks guys, that helped ALOT. What does cutter direction mean, in the set up? Normal,clockwise or counter clockwise? It means exactly what it says Share this post Link to post Share on other sites
randyb 1 Posted December 24, 2008 Mine is set to clockwise?Is that the correct setting? Share this post Link to post Share on other sites
cutme 5 Posted December 24, 2008 depends on what you are cutting. sometimes you may want to cut in the other direction because of the design. bb Share this post Link to post Share on other sites
mobby 1 Posted December 25, 2008 The clockwise & counterclockwise is not relevant for vinyl cutting. It is used to control the loop directions for dxf & eps files sent to routers that don't have their own software to reorder the cutting paths. For routing, the inside loop has to be in the opposite directin to outside loop. This is to ensure that the burr is always on one side ie the backside of the sign. Used in conjunction with "cut holes first" it also ensures that insides are cut first, as they must be for routing. It is also an advantage if you a cutting small letters, because if the outside is cut first, the shape make come loose from the sheet when the inside is cut. An example would be the letter "O" mobby Share this post Link to post Share on other sites
