chshirl
help cutter stopped cutting!
I had been cutting out many different projects and went to start a new one and all of a sudden it wasn't cutting anymore. It was acting like it was cutting, going through all the motions and such but the blade never actually cut anything. Its as if the carriage is broken or something. I tried doing a test square, same thing goes through the motions but no cut. I tried the pressure nothing. I hadn't done anything different with the machine when it stopped. I am stuck. Please help.
does the carriage move down when it should be cutting, or is it just sliding back and forth and not dropping down for the cut?
if it is dropping down during the cut strokes, then re-seat the blade holder and make sure that you tighten up the blade holder cuff screw pretty tight.
let us know what's going on. it would also help to know which cutter you have.
I have the pcut creation series. No the carriage does not move up and down. It just moves back and forth.
It is so strange one minute it was cutting and the next minute it wasn't.
Ken,
What are you doing working on a Sunday Night!!!!
Dave
Was at home checking on things....
:thumbsup:
