Celerity Photography
Members-
Everything posted by Celerity Photography
Maybe I'm missing something, but when changing settings such as blade offset and overcut when using a 1st Gen SC cutter and SCAL 5 Pro, nothing happens? I don't see any changes. I'm having an issue where my corners are just slightly rounded, instead of square. When changing the blade offset, nothing happens, same result, even after adjusting +/- 1.0mm. I've tried to update the driver for the cutter, but it says it's up to date. I have also tried to uninstall the device and reinstall. Is this a communication issue or am I missing something in the settings of SCAL 5? Thanks for any help :)
1st Gen SC and SCAL 5 Pro
Celerity Photography replied to Celerity Photography's topic in SC Series Vinyl Cutter Discussions
After doing some troubleshooting with USCutter and Craft Edge, the issue ended up being the SCAL 5 Pro software not communicating properly with the SC cutter, not the blade settings. I've received a copy of VinylMaster and have no issues now. I'm going to continue to work with Craft Edge to see if we can get the issue resolved for others having the same problem. -
I've had this cutter for about 5 years now and know how to set it up properly, but something has changed and I no longer have full control of the settings. Something else to note is I recently upgraded from SCAL 3 Pro to SCAL 5 Pro, so maybe the software is the issue? Haven't cut much since upgrading, so I didn't notice the difference in cut quality. -
Skeeter, I followed your advice and backed the blade down to where it's barely showing. Tested on a scrap piece of vinyl and ran the test through my machine again. Same results. -
I always test my blades with a scrap piece of vinyl and I'm just barely scoring the backing paper, so I don't think the blade or holder are the issue at this point. New blade, new holder. -
Half a credit card. I've even tried backing it off a quarter and half-turn to see if that makes a difference. And to note, my cutter speed is normally set to 300mm/s and pressure is 50g. I tried going down to 100mm/s and 20g to see if that helps, but same result.
