dave1510
Posts posted by dave1510
How can you cut one file after another without going to the file, cut it, then having to go to another file and cut it, so on and so. Just setup your plotter and go.
One thing I would change on the Titan 2, are rather add to, is the number and spacing of the vinyl clamps. It only has 4. There is a roller for a fifth, but not a clamp for it. They should have six spread out, so you could use different size vinyl.
When you go to cut, it gives you an option of the quantity you want to cut. How to do increase the space between the cuts. For example you chose to cut a quantity of 3, I want to increase the space between the 3 cuts.
I have pro.
How do you increase the space between tiles, when you increase the quantity to 2 or more.
Thanks
Anyone know a trick to get bubbles out of vinyl applied to aluminum?
What ended up doing is going to the contour cut mode, saving it as a pdf, then loading it into photoshop elements, then printing it out after adjusting image, then contour cutting it out on my titan, using vinylmaster.
I know that's a run on sentence. sorry.
cobra ink pigment
If I print out of Gimp or Inkscape it's fine.
Sorry I have an Epson 7110.
I have pro. It may not have RIP, but it has a print icon. The colors is off.
How do you install your printer profiles in Vinylmaster pro?
I PRO.
BUT I WANT TO PRINT THE BACKGROUND. JUST LIKE A PHOTO. A SQUARE.
I'm trying to print an photo using contour cut wizard. I'm trying put my cut line into the boarder but it vectorizes the whole image. What I want is to put cutbox around the photo so I can adjust the cut-line.
How can you use a laser printer to print an ink transfers with white in the transfer?
Still can't do it, but I did make a video>
I'll be cutting up a storm then all of a sudden when the blade gets close to the edge, the vinyl will bunch up. I don't think I have my rollers in the right position. I'm cutting HTV @ 400 with 90 pressure.
thank you
- 1
How do you pause a titan 2?
When I hit combine, the gap closes.
Thanks for all your help!I still can't join nodes together. If I draw a polyline, go into node editing, and try an put the end of that line onto the end of another line, they do not connect.
How do you delete spans or lines between nodes, and how do you connect two different lines together?
I think I need to be able to say remove a section of a circle, so that it's not a close circle, but has a gap in it.
The problem with punch-out, is that it is not open ended so when you cut you have no bridge to hold the piece in on your stencil.
If you have two circles, one inside the other and you join them together with a rectangle, so that you have two circles with a rectangle on the edges, Now erase the ends of the rectangle and you have a open path to the inside of the inner circle.
It's what they call a bridge in stenciling. This is so that when you cut your stencil you have the inside of say a O hanging on by thin pieces. That way you paint your stencil and just touch up the bridges and it's no problem. Without the bridges the O would be just an empty circle.
I know that's clear as mud.
Cutting multible files.
in VinylMaster CUT, LTR, PRO & DSR
Thanks!
