pilotman1
Days Won
Posts posted by pilotman1
Im getting into heat transfers and wanting to know the best blade to use for cutting sister stretch vinyl and also blade pressure.
thanks for everyones input.
chad
I have a laser point 2 plotter and just now getting started cutting sister stretch, the problem is when the plotter is cutting the design every once in awhile the vinyl bunches up, therefore screwing up the design also what is the best blade to be using when cutting heat transfer vinyl.
thanks for any suggestions.
I looking at Epson printers to do small sublimation projects for fun, thoughts on the 2750 Epson printer?
Thanks
heat press
in Vinyl
Im looking at purchasing a swing arm heat press, what is the best size press to get started?
I am working on a project which has big fonts which are going to be red,, and will have a quarter inch black trace around the fonts,,, trying to figure out how to do the trace in black,, any help is greatly appreciated.
I am new to the printer for sublimation thing, my budget at this time is pretty tight, I was looking on E-bay and saw a Epson stylus C88 plus printer w/ 200 ML DS sublimation ink,, is this worth buying or should zi wait until I have enough money to buy the 7610.
thanks for any replies
OK, so I bought the heat press machine for mugs, now I am wanting to buy some different size wraps, question is, do all wraps work with all heat presses? or do each company have their own wraps?
On a mug press get one that you put the mug in on it's side. This gives you the option of doing water bottles and stuff without having to put your image at the bottom of the water bottle only. You can slide it in to where you want it.That Makes a lot of sense!!!! thanks!!!!
I am ordering some cactus wraps but want to also buy a press for doing mugs, any suggestions on a press, upright or laying flat, pros and cons of heat press.
thanks
And don't forget to give Richard (cobra ink) my name and he will take 10% off of whatever you buy ...you rock mr300!!! thanks and I sure will.
No, it is not. Ricoh/Sawgrass ink is very expensive. That's why I, and many other cheapskates like myself use Epson printers with Cobra Ink sublimation ink. You can pick up a 13x19" Epson printer (which is also an 11x17" scanner) *and* a Cobra Ink CISS kit *and* a fill up of Cobra Ink sublimation ink usually for less than the cost of a Ricoh and the first set of ink cartridges.An Epson 7510 with shipping and handling will cost you $149.00 and a CISS kit with 4 oz. of each color ink will run you $219.95, or about $369.
One set of cartridges for the Ricoh will cost you about $325 and another $325 when you need to replace them. A 16 oz. refill kit (4 oz. of each color) from Cobra Ink is $79.99, as I recall and has about 4x as much ink as a set of Ricoh cartridges.
An Epson printer requires a lot more fiddling than a Ricoh, so if you want a printer that you can plug in and forget about until you need it, go with the Ricoh. If you're willing to take the time to print regular test pages and perform the occasional cleaning cycle, you can save a ton of money with an Epson/Cobra Ink system... Money you can spend on your new sublimation addiction...
Thanks OW i will check that out as I am just getting started at looking before purchase, thanks for the advice!!!
Thanks, mr300s, I am also looking at a sight called heatpress nation.com looks like the ink is not cheap
Looking at purchasing the Richo 3110 printer kit, to get started on doing mugs, any suggestion??
Thanks.
I am looking at getting into putting photos on mugs and plates, any suggestions for a good printer for mac book pro.
thanks.
I've used 651, 751 and reflective with good long term results.Thanks jaybird.
As in legitimate DOT regulated street signs on behalf of a government body (city, county, state, etc.), or decorative street signs? If decorative, indoor or outdoor?They will just be for decorative and will be used both for outdoor/indoor use
Wanting to know what would be the best vinyl to use for making street signs?
Hafa dai, I lived in Saipan for a long time, looking at moving back the end of this year, my girl is the manger for power 99 the radio station and I am good friends with dice, she is one of the DJ`s at the station.
I purchased a plooter laser II this last summer and am working on getting things going here then pack it all up and move back to the island, are you working with anyone or you just doing this for a hobby?
My name is Chad
what kinda of cutter do you have. and yeah the tracing came out really bad I would not sell that not even give it away to them.that was a practice draft
Thanks guys!!! I appreciate your input!!!!
Great layer work!!!!!
I have used both an HP and now my mac book pro, I find it easier and faster to do my designs with the mac book with SCAL pro4, I have gone all back to mac as I was PC for a couple years and could`t be happier with the switch.
I am new to the decal business and it is sure keeping me busy and thanks to USCutter for all their info and help.
- 1
tracing/cutting
in General Help
I am to cut a clip art of a bicycle but the tires are coming out perfectly,I have tried changing my tracing effects and still not happy with the turn out.
Any advice?
thanks
