Primal Decals
Members
  • Content Count
    2,241
  • Joined
  • Last visited
  • Days Won
    40
Everything posted by Primal Decals
  1. Primal Decals
    looking for american flag racecar graphic
    Thank YOooooooooooooooooooouuuuuuuuuuuuuu maftty500
  2. Primal Decals
    What are cheapest vinyl vendors
    Oracal all the way. except when i buy my Camo 3m and Siser for clothing .
  3. Primal Decals
    new member
    Welcome @zip2it . Im a good buddy of cardudenc.
  4. Primal Decals
    How do I cut outlines?
    Thats basically how i do it my software but its not VM.But in mine its called shadow is what i use.
  5. Primal Decals
    Best/Good Heat Press Brands
    I have the fusion as well 16x20 bought it earlier this year i think lol.. Great press. So glad to have it .It was my first press ever.
  6. Primal Decals
    Shipping layerd decals
    I guess i should of mentioned that it has some weight to it .there was multiple items in with the decals as well.
  7. Primal Decals
    My last shipment was about 13 bucks i believe. and the size was roughly 22"x30". wouldnt hurt to just go there and get a quote on a size before you just do it.
  8. Primal Decals
    Material help on HTV
    Thanks Goose.
  9. Primal Decals
    I prefer to ship as flat when its thats size. You can just a get a couple boxes and cut them down to make them flat and just tape it very good around the edges. and write Fragile on it on both sides.I think the cost was the same and you have less to worry about for tunneling.. . Just my Opinion.
  10. Primal Decals
    Roland pnc 1210 how old?
    here is the manual for you.. usermanualpnc1210.pdf
  11. Primal Decals
    found this ---
  12. Primal Decals
    Yes. Customer supplied .the brand of the jackets are Augusta sportsware which i probably should of mentioned before. Rn# is 65378 with a style #4392 inside the jacket. I already warned them in the beginning just to cover my rear..
  13. Primal Decals
    @Wildgoose any thoughts.Thank you . My deadline is getting near on this and im starting to freak out a little .
  14. Primal Decals
    SC Uscutter Not Finishing Cut?
    Oh ok thnx . I think it should just be out in plain sight .Since its a very important key note. but i guess it will do lol.
  15. Primal Decals
    I think there should be a Main Tab on the main forum page that says -" Start Here"---- How to set your blade depth before you start cutting anything. That way when a new person shows up it will be Right there on top...Some people may not even know how to describe what it is called etc and they end up having to ask the Million Dollar repeated question lol..
  16. Primal Decals
    ipf610 wide format printer works great paid $400
    from the model # i looked online and it say 24". https://www.canon-europe.com/for_work/products/professional_print/large_format/ipf610/
  17. Primal Decals
    Hello, Newbie for Ohio
    Hows is going @Chriscarp746 ?
  18. Primal Decals
    @mfatty500 So luckily i was given a spare jacket to keep to play with,they are really working with me to make sure all goes well on this ..So i used Your suggestion on the test jacket at *310 for 20 secs @ 3 pressure, and i still ended up getting a heavy press line ,not bad but its visible. Is this common or should i lower it down to 2 ? I also used a pillow press to keep the image area to be pressed raised as well but the pillow still flattened out enough to make the sqaure heat mark. The htv held perfect when peeled as usual ..Thank you. P.s. As im writing this i am washing the jacket to see if anything changes,cause i read sometimes washing it will make it go away . not really thinking it will ,but it wont hurt i guess till i hear back from you or anyone.. Thank you again.
  19. Primal Decals
    Does this Vinyl Exist?
    Thanks @ShaneGreen and @jmas . he is wanting more glitter than the metallic produce like what Mz skeeter posted.
  20. Primal Decals
    thats the closest ive seen so far ,thank you for the link.
  21. Primal Decals
    No. Actual glitter like what Siser htv is but not htv . but made in a cast etc like 651-751 and so on.
  22. Primal Decals
    Max Mat Size SCALP4
    the pro version is much better. Im running Ai with scalps4pro upgraded from 3pro 2 years ago. .What you have to consider is what your cutter can handle for memory if your doing long cuts and the size of the design if im correct.
  23. Primal Decals
    Help with clip art
    i think i might have some , will have to check when i get back from a install. sent you a message as well bud.
  24. Primal Decals
    Merry Christmas
    Nice Choice bud.
  25. Haha ---I actually seen a cutter yesterday in a tattoo shop when i was out of town that had the same color of the titan carriage, there was no label or name anywhere on the cutter and it wasnt a titan. the display was even really strange looking with numbers not words . The cutter itself was black and grey and the cutting strip was huge.
