101LEDs
Members-
Days Won
2
Everything posted by 101LEDs
You could try, not sure if the backing will curl or shrink as they dry.
Here is one with the SignBlazer 200 fonts in it. http://www.4shared.com/zip/LIi7aa_Zce/SBFONTS.html It was too big to upload on here, but it's mine and safe.
I think your fighting a loosing battle on this one. Possibility of having mold spores on them would make me toss the batch.
I was starting to wonder about power surges or spikes since so many people report problems after sitting for awhile or even overnight.
Some foods are prohibited in certain countries. You would be surprised at the lists they have.
NEED HELP INSTALL A THEMOS ASAP- I HAVE AN EVENT!!
101LEDs replied to vford09's topic in Website and Company Feedback
Here is the manual. Hope it helps, if not you should have a local electrician take a look. xmt manual.pdf -
Ideally you would just swap wire for wire to each position from the old to the new. Need a better picture of the new thermostat controller, the sticker with numbers 6-10 really. -
Was it plugged in when it was sitting unused?
Just wait until you try the second cut.
Bought a Red Bull drink in the last 12 years?
101LEDs replied to Sal316's topic in Off Topic Section
For anyone that thought they would grow wings, needs to put the money towards a head check. -
Customs is quick and easy on items like that. The only time there is a delay is when they have an amount of packages that is larger than usual. If they are in Cali, where is the ink shipping from? Have any type of tracking or customs form number?
To draw the mounting and drilling templates for a DIY install on this mid 1800's cabinet. It is used to display old glass pieces and Uranium glass. The uranium glass is UV reactive so she wanted blacklight LEDS that are remote controlled and dimmable. It is over 8' tall and almost 6' wide. It would of been a on site job except she lives on an island off of Newfoundland. Used the cutter to make templates the size of the shelves (non removable)with all the mounting locations so they could be taped to the underside and lights installed through the cutouts to keep everything straight and equal.
054 Turquoise or 173 geyser blue, both go with black and white.
Here is one you might like. 2colorpins.svg
Try this one. It's the biggest frame. Large frame.svg
I got it from the first DL. Scut3. Not the second. So it wasn't the switch. Try cutting something else and see if there is a problem.
Welcome from Ky.
You need to redo the frames, on 2 sides they have dashed lines instead of solid. Is it cutting it like a perforation?
http://www.uscutter.com/RazorCut-Design-Contour-Cut-Software And It comes with the new Titan 3 cutter that has vacuum hold down for light materials.
That is a vinyl for wrapping. You might have to try several types of paper tape to find one that works.
Carriage Compatibility
101LEDs replied to Kickfacer's topic in LaserPoint Cutting Plotter Discussion
Very doubtful. Even though they share the name that USC gave them they were built by two different companies.- 6 replies
- Maintenance
- Laserpoint 1
(and 1 more)
Tagged with:
If they don't need it for a Black light effect and just the bright color you could put a UV blocking film over it to extend the life.
Looks good,
There are more options for cutting. You can rotate the image 360 degrees in 90 degree steps, nest the objects, use all of the alignment tools and more. You have to click send to cut file instead of send to cutter.
