Beavis97
Members
  • Content Count
    140
  • Joined
  • Last visited
  • Days Won
Everything posted by Beavis97
  1. Beavis97
    Printer option?
    Ok. I am looking i to 2 different printers just to print out some small decals on printable vinyl. Now some require bright colors. I have a workforce 1100 right now, but can not get some of the brighter colors. I was looking in to the Epson Artisan 1430 or Epson p400. Anyone habe any experience with the 1430 or p400?
  2. How do you install icc printer profiles on vinylmaster designer?
  3. Beavis97
    Printing bright colors?
    Anyone know how i can print bright colors like this. What type of equipment i need.
  4. Beavis97
    Some Printed decals
    Here are some small decals i have just started to try out. I am using an Epson 2000 and 1100 printers(pigment ink) with matte white printable vinyl and oracal transparent laminate. Just started doing some and if anyone has any other helpful tips would be great. Been looking for fluorescent printable vinyl.
  5. Beavis97
    Some Printed decals
    Yes I have noticed s bit of shrinking. Was cutting both vinyl and laminate at same time, but may have to find out how to do an overdcut and cut them seperate
  6. Beavis97
    Some Printed decals
    So far good. Have had one sitting out in the sun for 3 weeks with some RC nitro fuel that I poured on it to test how it would hold up to that part too
  7. I upgrade fron cut to ltr and everything still loads up as cut after I download from the link the gave me that says download vinylmaster ltr. Do I need to uninstall the old one first?
    1. VinylMaster
      VinylMaster
      No just use your new PSN when installing.
    2. Beavis97
      Beavis97
      Ok.. Thank you. I found that I copied the wrong PSN down and used the old one again. LOL
  8. Beavis97
    USCutter PSN VinylMaster Update
    So when you upgrade from cut to ltr. I downloaded new, but it still loads up as cut and don't see any of the new features
  9. Beavis97
    Fluorescent colors?
    Wondering how people print these types of colors. Someone was saying that there is a Fluorescent colored paper you can print on? Any info on any of this?
  10. Beavis97
    Contour just a bit off?
    I messed around with the offset and also re-calibrated the laser and it is a lot closer. See how this all works out.
  11. Beavis97
    Trying to figure out the contour stuff and got it pretty much, but they are off just a bit. This is a photo of my first printed decal job. I have a SC 54in and use vinyl master cut. Would it be the offset in the program that I have to mess with?
  12. I just bought an SC 54in cutter and sometimes it does not finish cuts in spots on what I am cutting out. It does not do it all the time, but if I cut more than one decal at once that is when it will most likely do it. Something like not finishing a line all the way or maybe a letter . Just somewhere on the decal it will not finish something. Just wondering if anyone else has had this problem before
  13. I have been using Vinyl Master Cut, Inkscape and Vector Magic. Sometimes I still go back to Signblazer til I get use to the Vinly Master
  14. Thanks for the help guys. I got the Tripp lite serial adapter and replaced the cutting strip. looked a bit worn. Seems to be doing fine now
  15. I am wondering how old the Roland pnc 1210 are or how long have they been around. I have a customer tha is throwing one away and I plug it in and turn it on and can hear all running and blade carrier moves like usual when turned on. Don't know much else yet until I get it home though. Right now I have a MH871 and SC 54in cutter.
  16. Beavis97
    Roland pnc 1210 how old?
    Thanks will check it out when I get home. Was trying to do a quick search on my phone. Will try again
  17. Beavis97
    That's what I kind of figure. For free sure the heck gonna try it. Lol. Was just trying to get some info. Tried to Google spec on it, but didn't find them yet
  18. I don't think the blade depth is the problem, but double checked anyways. Sometimes it will cut fine and then other times it will just be in a random spot on the cut where it does not finish the line that it is cutting and goes on to somewhere else and starts cutting. I know these are low end cutters, Had an MH871 for 7 years and never had it do this. I just got the Vinyl master Cut and is all new to me. Was using Signblazer before. For $100 just couldn't pass up the cutter and other stuff it came with. Would really like to put some money away to get a good servo motor cutter.
  19. Ok I will check that all out. Yeah was just reading some of Skeeter's post on that. Thanks for the info. Really want to get a servo motor cutter soon, but man someone sold me this machine, box of vinyl, tools and few other things for $100.. Could not pass it up. LOL
  20. If I buy VinylMaster Cut from Uscutters is it a download and do I get an activation code right away or is all through the mail?
    1. VinylMaster
      VinylMaster
      You can download it as soon as you get your PSN from here:
      http://fcws1.com/usc.htm
  21. Beavis97
    Trial Counting?
    Why does the trial version start to count how many time you use the signblazer after a few times? I have re-installed this and it stop for a few and then it will start counting again right next to the trial button? I have had it get all the way up to 20 and it won't let you click the trial button until it stops counting.. Any ideas?
  22. Beavis97
    John Deere Trackor
    I am looking for a side view of a John Deere Trackor in a vector file.. I have someone that there daughter want the trackor in pink.. I have googled and can't seem to find one that looks good enough.. any help would be great.. Thanks
  23. Beavis97
    Sublidecals
    I had just purchased some of this sublidecal sheet and I tell ya I like the results so far. http://www.facebook....klenshinedetail
  24. Beavis97
    Sublidecals
    Well the sublidecal paper has the vinyl on top and a backing to the vinyl. I have trimmed around the stuff with a razor blade. cuts easy or you can contour cut it. Which I dont have a laser eye for my cutter..I might have to invest in a smaller cutter for doing stuff with this sublidecal. I got mine in 11x17 in paper. Also comes in 13x17in sheets
  25. Beavis97
    SignBlazer E. and Register pop up form
    Thanks for the PDF file..It took me a bit but I finally got it and it worked...Thanks for your help
