han7681
Members-
Everything posted by han7681
hi when i turned on the cutter, Novram Init message showed then , the cutter didnt move at all, even couldnt load , tried factory setting - hold up arrow key and power on , but nothing changed. anyone knows why and how i can sort it out? thanks
hi done factory resetting , but once power on , some weird things show on the screen , as below it is supposed to be 1st photo , any idea why? it may be cable problem? slightly damaged when it was pulled off. where i can this cable? thank
after factory reset, doesnt work !!!!
han7681 replied to han7681's topic in GraphTec Cutting Plotter Discussion
hi originally it showed "Novram Init " thanks -
the photo is attaced. cant control any. , im using signblazer have to change motherboard? it it is replaced, what is need to set?
hi i will print wall paper covering around 2x3 M as its size , will divide 3 or 4 section , overlapping 1 cm the photo size is 30 cmx28 cm (300dpi) 34.5 MB how to cut into 3 or 4 sections and change size and resolution in photoshop? thanks
how to divide the photo and change resolution to print?
han7681 replied to han7681's topic in Printers
hi i have roland rs 640 and versa works will print on oracle 3268 vinyl thanks -
hi as showing on the photo. http://cafeptthumb3....y.jpg?type=w740 it is very thin plastic sheet , how do you call it and when we can get it? i guess it cut by Silhouette Cameo. can it be cut by normal cutter like ce-5000? thanks
hi the photo is attached
hi i cant merge with the butterfly body with other part. how i can make one object? any idea? thanks butterfly body.eps
hi anyone know how to do in AI ? thanks
hi thanks for answer.. but can you explain how to weld? i tried to expand , but cant press the expand button in pathfinder. thanks
contour cut and signmaster 2 cutting error?
han7681 posted a topic in GraphTec Cutting Plotter Support Requests
hi plz see the photo, the cutting is not correct position , set reg mark in signmaster 2 and send to graphtec cutter what went wrong? printer problem or cutter settling wrong? whole graphic size is 60* 20 cm ,, any idea? thanks -
hi i have few cutters with each pc to run. can one signblazer in one pc run many cutters? if yes, how to do ? any advice welcome thanks
hi thanks for answer , i manged to cut 2 cutters with one pc, but whenever cutting a new, do i need to change output device setting? for example. open a 2 sign blazer, then one is usb 1 output setting in signblazer , the other is usb2 output setting in signblazer , after cutting finish, usb1 always change into usb2., so have to change back to usb 1 when cutting a new one, how i can solve? how i can fix the usb out ? thanks
thanks for replying i have PCUT CREATION.
hi as u can see the photo, when i cut the image file, the knife goes everywhere. not follows the path. similar things have happened in Artcut,never in Signblazer. any idea? Untitled-1.eps Untitled-1.eps
HI as shown the photos, one corner in square is not clean. i have chaged the offset from 0-7.0 square size is 5*5cm all same results... any idea why?
hi im usuing a pcut creation
hi offset from 2.5-4.0 it looks like the photos what is the problem? if offset is worng, it looks like this? or blade depth is wrong? help!!!
hi after outline the letters in illustrator, importing then cutting but it cuts 2 times , it cuts and cuts again folllowing first line exactly any idea? why?
thanks again, i just realized even when i type the word in sign cut, it cut 2 times. well , setting problem?
thanks as showing the photos, i try to drag the letters, but i cant did i miss the point what u said? or i have to do in the illustratior?
thanks for reply can u tell more ? how i can delet the layer?
hi the path was fine in illustrator cs2 (photo bottom one) but when importing the artcut, it was not correct (photo upper one) anyidea why and how can i correct?
hi how can i correct into straght line? i want to make it straight line ( angle 0) thanks Untitled-1.ai Untitled-1.ai
