Days Won
21
Everything posted by mb20music
Cutting cardstock?
mb20music replied to sddimaio's topic in USCutter Refine Cutting Plotter Support Requests
Well according to the "Specifications" for the MH series you can cut card stock, probably can't do anything real thick though. As far as special settings, you will need to extend the blade out and use more pressure, will take some trial and error. http://www.uscutter.com/USCutter-MH-Series-Vinyl-Cutter-w-VinylMaster-Cut-Design-Cut-Software -
https://fullspectrumforum.com/split-monogram-fonts-t860.html
- 1 reply
- 1
My impression of the Refine MH721
mb20music replied to BannerJohn's topic in USCutter Refine Cutting Plotter Discussion
custom drawn on the "About Us" Spokane, WA should be: OzHandicraft BT (Roman)
http://www.uscuttersupport.com/downloads/Software/SignBlazer/signblazer_setup.exe
The font for "Kiefer Built" I believe to be: Americana (Italic) The letter "B" in "KB" I believe is: New Berolina MT Std (Regular) However, the K is not the same font, can't seem to match that one...
You can use any brand vinyl with that machine.
full color or just one color?
HELP!! Having issues cutting heat transfer vinyl
mb20music replied to mchldelf's topic in TITAN Series Vinyl Cutter Discussions
Something you maybe want to try is do the same "cut" but this time remove the blade holder from the carriage, that way we can tell if it is the pinch rollers causing it or if you have too much down pressure causing the blade holder to drag on the htv. Slowing down the speed a little might help too if you haven't already tried that. -
can you upload the video clip to youtube? -
Yeah there is no way it can be 210mil thick, that would be about 5mm or about 1/4" thick. Most PPF is only about 8 mil which is about twice the thickness of sign vinyl...
The closest font I found is this: Could modify it to match https://www.dafont.com/middlesaxonytext.font?text=13
This is pretty close, but slightly modified (squished together a bit) lol Need to modify part of the letter "G" as well... https://fontsup.com/font/serpentine-sans-icg-bold-oblique.html
"WILSON THEATRE" is: Bellerose
Its Fun having a Vinyl Cutter around Halloween
mb20music replied to Jburns's topic in Show your work
Should have put the Mcdonald's logo on it, LOL -
What are you going to be doing with it? you aren't planning on using it for outdoor signage are you??
looks custom to me, notice how the two letter i's and the two letter F's are different??
The link is no longer active!
I like the "before" better, JK! LOL
Well, there is a sensor that detects when the lever is up or down, you would need to remove the plastic cover nearest the control panel side of the machine to get to it. This may or may not be the culprit. Make sure the white connector is plugged in to the sensor. I suppose the sensor could fail but I don't think it would be unlikely since there are no moving parts on the sensor itself. Also, I suppose you could try a factory reset by holding the arrow up button while turning on the cutter. Another thing, were you trying to cut too small of a piece of vinyl? The vinyl has to cover the rear sensor of the cutter or it won't allow the cutter to proceed. Something else you might try is turning off the sensors in the cutter setup menu.
Well if you are wanting it single color instead of full color, try this. I also added the text you requested... warriors_alex_decal.EPS
Did you adjust the selection tolerance slider? try adjusting it to a little bit past the 3rd line on the slider and select the capital letter "N"
