mb20music
Members
  • Content Count
    2,623
  • Joined
  • Last visited
  • Days Won
    21
Everything posted by mb20music
  1. mb20music
    Single tag states
    she googled it and copy and pasted it lol
  2. mb20music
    magnum force 2 cutter
    Your best bet would probably contacting Signlab or SCM
  3. mb20music
    Cutting Issues
    does the blade spin freely in blade holder?
  4. I hear powering off your vinyl cutter after each job may help as the budget/hobby cutters have very limited memory.
  5. mb20music
    Font help
    you should invest in find my font findmyfont.com
  6. Well I would assume he is probably looking for ideas for things that he can do with a vinyl cutter and heat press, can't do pens with a vinyl cutter or heat press....
  7. mb20music
    Cross with praying hands and rosary
    yes he is right, not even close to what he asked for
  8. mb20music
    Signblazer. Crashing
    what exactly are you doing in Signblazer when it crashes on you?
  9. mb20music
    what tape top use for doing layers?
    When layering, clear tape makes it a lot easier if you ask me!
  10. mb20music
    dingbat fonts
    Yes you are correct, that is a much easier way to do it. I tried to copy and paste and it didn't work for me the first time I tried, but I just tried it again and it worked...
  11. mb20music
    dingbat fonts
    In Signblazer, type this: (alt)+0207 while holding down the alt key, type +0207 What you do is open Character Map then click on the desired symbol at the bottom it shows the "keystroke" for that particular symbol
  12. mb20music
    New Inkjet Printer....
    JPSS Sofstretch
  13. mb20music
    where to find
    You can cover plain white ones in glitter vinyl
  14. mb20music
    Finger nail art
    What vinyl cutter do you have? if you have one of the "budget" cutters you most likely won't be able to cut that small successfully. But generally, when cutting very small you want to cut very slow, pressure you shouldn't have to adjust at all.
  15. mb20music
    Vinyl Cutter Burning Smell
    sounds like you need a new motherboard. Do any of these look like your motherboard? http://shop.uscutter.com/search?w=mh motherboard
  16. mb20music
    similar font help
    https://www.dafont.com/theme.php?cat=110&text=ABCDEFG&fpp=100
  17. mb20music
    Using Precut Vinyl sheets
    no, unless the design is bigger than the sheet, of course.
  18. mb20music
    ce5000-60
    The CE5000 has been around since 2006, I believe the CE6000 came out in 2015.
  19. mb20music
    help with pcut cs630
    Should be 9600, I do believe
  20. mb20music
    Help with a Roland PNC 1000
    SignBlazer You may or may not need to disable your virus software before downloading, file is completely SAFE to download. http://www.uscuttersupport.com/downloads/Software/SignBlazer/signblazer_setup.exe
  21. mb20music
    Printing from Silhouette studio software
    Maybe also try to contact Sawgrass and/or Silhouette https://www.sawgrassink.com/Special-Pages/Contact-Sawgrass.aspx email: support@silhouetteamerica.com
  22. OR Signwarehouse Q Series
  23. A less expensive option if you want the "sheet cut" capability (also called cross cut) would be a Signwarehouse Q Series which is basically a Graphtec FC Series that is rebranded with the Signwarehouse name. The Signwarehouse Q Series 24" is about $1000 less than the Graphtec FC 24".
  24. mb20music
    image cuts randomly
    According to his other posts he uses VM LTR
