mac6986
Members
  • Content Count
    222
  • Joined
  • Last visited
  • Days Won
Everything posted by mac6986
  1. well what exactly was the "phrase" that was trademarked that you are in violation of? You cant trademark common phrases. 20th Century Fox had ebay take one of my listings down. I had a euro oval decal with just the word "giggity" in it. there were no references or images to the character or the tv show, but since its such a unique word, and not common place, it warranted removal as a trademark violation. Honest mistake, I didn't think it would be a violation, but it was. They just simply had ebay take it down, I spoke to a FOX I.P. rep, and they were very polite, and just said since the word is unique to the tv show, they had the right to do it. oh yea, and then they said "DONT DO IT AGAIN!" Also, there are sellers out there that just message you and say they have the trademark/copyright, just to scare you into taking listings down so they will have less competition. I would ask to see some sort of documentation or registration proof.
  2. OK, so I just recently upgraded from a hand crank laminator, to an Diage Solo electric laminator. When I was doing things by hand, my sheets of lam were cut to size and I discarded the backing imediatley after use. NOW, the solo has a backing paper take up reel, and im about to change out the empty roll for a new one, but I have 50 yards of laminate liner rolled up on the take up reel. First, its a pain to get it all off because to start it, you have to tape it to the take-up reel. so I cant just slide it off. Once I got it off, I dont have a use for it, but it feels like such a waste to throw out THAT MUCH liner in one shot. Do any of you guys out there have uses for liners?
  3. App tape contracting more than the vinyl due to temp/humidity changes from the time of application. I would suggest switching to paper tape.
  4. Haha, been there, done that. If there was one quote that ever stuck in my head it was one from Steve Jobs " People don't know what they want until you show it to them." I don't want to have to deal with people coming back in a year or two so I just laminate everything and charge accordingly, and never even offer them without laminate.
  5. Pm me, I can print, Ill give you a good price, and guide you on what your markup should be.
  6. +1 on the laminate. No way you can compete on price for the amount of work involved to do layered vinyl Explain to him the benefit of a laminated decal, outsource it, mark it up and move on to the next job. You'll make more money for less work if you can broker the print job.
  7. mac6986
    Roland VersaCAMM SP-300V Printer/Cutter
    This printer has a seperate print spread and speed just for banners. at its highest speed, you can print up to 70 sq/ft per hr. On a 30" model, thats just under 6 linear inches per minute at the full 30" material width. Tthe higher the speed, the lower the quality though, but for roadside banners, and banners strung up high, crystal clear, razor sharp images are not always needed. just get yourself some hemming tape, and a grommet machine and you're set.
  8. mac6986
    I would recommend it. I'm a little bias though, I'm on my second printer, both of them Rolands. I've had no complaints. I started with the BN20, good machine to get your feet wet, but once you start offering printed graphics to your customers, you'll find out real quick that this particular printer was not built for any kind of production speed. From print speed to cut speed, it's slower than molasses in winter. Once I moved into a large enough space, I spent the money and got a brand new versacamm VS-300i. Oh man, I wish I hadn't waited as long as I did to upgrade. My niche is small decals ( under 5") and reflective graphics for emergency vehicles. This machine is more than enough for me. The versacamm is a great all in one printer. If your print demand increases ( which it most likely will) couple it with a gx300 cutter, and you can let the printer print off specific lengths of material, and while that's going on, you can take the finished prints, laminate them, and cut them separately, saving you tons of time. I've seen them all over the net used, you can pick them up for anywhere between $5-8k. Now the other side of the coin. These machines need about as much attention as small child would. They need to be fed properly (OEM inks highly recommended) and cleaned on a regular basis. These things also don't like to sit around with nothing to do, you need to print things off regularly to keep the ink from getting stagnant in the lines, dampers, & heads. You can't just print on any old vinyl, you need to buy the proper solvent printable vinyl. Some jobs will require you to laminate, there's more material and another machine. Some people use a big squeegee, there's too much "silvering" when I use a BS, I personally would recommend a hand crank or electric cold roll laminator. The upfront cost will be more than just the purchase cost of the printer. Keep that in mind while window shopping.
  9. mac6986
    Vinyl on wood
    X3 on the stencils. Will look better after being covered in epoxy because there will be no height difference between the wood surface and graphic
  10. mac6986
    SunIE Poor Customer Service
    +1 I agree with Go-C. Its only been 4 business days, ( 3 technically if you ordered after 5 pm local time ) I highly doubt they have them in stock at their facility. They most likely drop ship them straight from the manufacturer. I would give them 5 business days for an item of that size before I start poking them for information.
  11. That's why they added the image attachment option in the eBay message system. One more reason for them to say "There's no reason for you to contact them outside of eBay." ( even though you get their email address when they make a purchase anyway )
  12. If you were to follow the terms and conditions to the letter, no it's not allowed. That being said, the only way that eBay would know you are doing it, is if someone were to report it. And the only reason I could think someone would report it , is if a competitor bought your item, saw it the insert/flyer/biz card and just wanted to start trouble. I put stuff in my shipments all the time. What's more in plain sight and easier for ebay to scold you on is links in your product descriptions. That's a no-no. You can refer other websites to your ebay listing/store, but you can't refer from a listing to an external site promoting items for sale.
  13. mac6986
    Surge Protection?
    Lightning is what it is. There's no surge protector out there that will guarantee against any and all possibilities. There is always that one bolt of lightning strong enough to push through the surge protector, no matter what its rated at. I will continue to leave mine plugged into the surge protector, and if an act of god comes along and fries my printer? Well that's why I pay for insurance. To put it all in perspective, you could spend thousands of dollars on measures to protect your electronics from lightning, yet the bolt didn't fry your equipment, it just set the building its all stored in on fire. Now where does that leave you? Its all relative, you can only do so much to protect your equipment. Take the right steps and be smart about it, but don't worry about the stuff you can't control.
  14. mac6986
    Surge Protection?
    Can't do that with most printers. They kick on every 4-6 hours and run self maintenance cycles to prevent heads from clogging/drying up. I run my VS-300i through a Monster HTS 1000 power strip. Can absorb over 6000 joules of surge, plus has ports to run cable and Ethernet through as well. You never know where the surge will come from. also run an APC UPS Pro1200 8 hour battery backup. I dont need a power outage costing me a $1500 print head replacement.
  15. If its guaranteed that you're getting the job, call up the big guy and get a price quote and see what he charges. Obviously don't tell him who you are or the address of the job, just give them the size, material you want and price to include installation. I've done that many times to just keep tabs on what other guys in the area are charging for different things. There have been many instances where I will do some work for a business friend and when I shoot them a price, they will straight up tell me that I am too low, and ask me to charge more. Ok, if you want to pay more, I wont argue. Another little tid bit, when you invoice, write it up as a full priced sign, the same you would for a complete stranger, but put the discount on the invoice as another line item, or before the grand total. People are more likely to remember that you cut them a deal when its in writing as opposed to just charging them the discounted price up front. Check out this write-up I wrote on pricing. Your sign is exactly what I used as the example sign and how to price it.
  16. mac6986
    Setting Up Shop "Vinyl Storage"
    True, I agree that it would drive me nuts too, having to un-rack 2 rolls just to get at one in the back, but thats the beauty behind the adjustable rack. all you have to do is drop the rows low enough that you can get the one in the back out between the top and bottom rolls.
  17. mac6986
    1/2 more on sign
    You're asking a lot of that machine to be that accurate over that long of a distance. The relative humidity and temperature changes can make material grow and shrink, coupled with the cut accuracy of a "hobby cutter", I'm not surprised. Even a Roland GX24 cutter has a cut accuracy of +/- .2% of the distance traveled. So in theory, two of the exact same cuts, 96" long, on a gx24 could have as much difference as .5" between the two of them in perfectly temperature controlled environment. Looking in the store, I cant find any specs on the cut accuracy of the PCUT. I cant imagine it being more accurate than professional cutter. If you are cutting vinyl to be applied to a substrate and that color needs to go all the way to the edge, Make it larger than the substrate and trim away the excess. other than that, looks like you need to get out the straight edge and fix the cut manually.
  18. mac6986
    Fold in a flash
    This may be way old news for some of you guys but I thought it was awesome when I came across it. Now that I am getting into doing t-shirts, this makes one of the more tedious tasks a lot simpler.
  19. mac6986
    Fold in a flash
    I just practiced this for like 30 minutes, and I have it down pat. What issues are you guys having with it?
  20. mac6986
    My Customer needs your help!
    +1 Never give a customer away just because they want something you don't provide in-house. Subbing work out is great because you're still making some money, while being able to get your other work done at the same time. As far as the customer is concerned, you made it yourself.
  21. mac6986
    Application fluids/NEED HELP PLEASE!
    If I had a dollar for every customer who came back and asked me to re-install their self installed graphics . . . oh wait, they paid me again anyway, lol. Parctice, practice, practice. Laying down graphics in essence is a very simple process but it takes time to learn the behavior of the vinyl when you do different things to it, and how different surfaces will accept the material. I recommend learning how to do dry installations (not on a paying customer job) because there are certain materials out there that you just cant install wet. lots of good videos on youtube. you're going to use up material to learn but its far better to practice behind the scenes, than to get to a job and not know what to do in front of a customer.
  22. mac6986
    Do press pillows wear out?
    Not your imagination, they do wear out after numerous pressings. I know Conde sells replacement foam inserts for their teflon pillows.
  23. mac6986
    Not sure how to do this...
    oh boy, time to go back to the eye doctor
  24. mac6986
    what program are you using? this is photoshop 101 stuff here. create 2 layers with the image you want on top use the eraser tool with a soft edge and erase the edge of the picture till it fades into the other.
  25. mac6986
    Needing A Quote
    not stealing dakotas thunder, but if hes busy and cant get to it, I can help you out too.
