Days Won
6
Everything posted by GraphxNMore
Wow.... you mean a trademarked image made it past admins??
Yes, use knockout.... but remember to copy and pace your letters first.
All you need to know. And I wouldn't go back and forth. Sublimation ink is too expensive. You'll have to refill the tubes every time you flush, and that's a massive amount of ink. A second printer is way cheaper than buying ink.
You can also grab the arrows in the middle of either the right hand side or bottom edge of the image selection window. Click, hold and drag.
How do I cut larger than my printer will print?
GraphxNMore replied to JessicaP's topic in Sure Cuts A Lot Pro
Why are you printing if you have rolls of vinyl? Are you doing color? -
Recreate the P. The rest is one of the Adobe fonts, italicized.
Need Help - Double cutting the image!
GraphxNMore replied to LKASurfing's topic in Sure Cuts A Lot Pro
Look at "Multi cut". It should say "off". It's in the window when you click "cutter" to cut. -
It's a bad trace. You'll be way more time ahead to just recreate. It's simple text with a rectangle.
I'll look at it, give me a few minutes.
Capone GG also fits, but commercial.
Texts are outline & can't really see them
GraphxNMore replied to vgabriele's topic in Sure Cuts A Lot Pro
Click view->show outlines only. -
How do I adjust it to be 8.5x14 instead of 8.5x11? (CS6)
There's no minus front in CS6. I send the smaller one to back, but minus back does nothing in the program. I get a message saying groups... yada yada.... this function may have no result....and it doesn't. There's a subtract, but it yields no result either.
One more question.... When sublimating coffee mugs, I need a rectangle at times for a guide. If I draw a white rectangle and add stroke, the white "fill" area always leaves a slight pinkish box. I've made it true white and even turned fill off, nothing stops it. I tried to do a minus back using two rectangles, but it won't do it. I can have the exact desired frame in 6 seconds using Scalp. Not sure what I'm missing. Clipping mask won't work either.
That's what I needed. Thanks! ( I never messed with it there in fear of screwing my sublimation settings, I figured there'd be a setting somewhere else)
When you "show print tiling"..... the box that shows your 'paper edges'.
Are they the same? They look identical. The SG400 is just supposed to be a faster version of the Ricoh. EDIT: I see a difference now, The electrical connection is vertical on one and horizontal on the other.
I did a couple items in November. We put our house up for sale, boxed everything up. Got moved in late June. I've done a few things here & there since moving in. Another thing I've noticed with the refillable cartridges is the amount of time from powerup to ready status is considerably shorter.
They actually have more vivid colors. Another thing I've discovered is I can reduce temperature to about 330 degrees on most items. I still use the profile Conde set up.
I've tried them all, and it's opinion. If he likes the layout, then try to help him. If you don't know the software, then scroll on past the thread. It actually makes you look like an a$$ when you get on here and basically belittle people because they don't use "professional" equipment & software. Yeah, that whole "my graphtec" looks like another jab. But you get on here and always bad mouth it, especially since the namesake of this forum don't push it any more.
So you admittedly tried it "years back", yet you continue to trash it, thread after thread??
Say whatever you want, but SCALP has all the features you need to do any job out there. We use ours with a Titan 2 and do complex 4' decals all the time. Just throwing that out there.
FMF isn't finding a match. I've done everything, even brush editing in paint after pasting & cropping. Any ideas?
Man, that's real dang close. A few curved edges here or there. Nothing I can't straighten though. Much appreciated!
