Days Won
640
Everything posted by Dakotagrafx
Head Doesnt Move Down to Cut
Dakotagrafx replied to ccsnv's topic in USCutter Refine Cutting Plotter Support Requests
Did you have the cutter stand grounded to the cutter? Submit a support ticket they will have you check the carriage and the probably replace the motherboard http://support.uscutter.com/index.php?_m=tickets&_a=submit -
Thanks
have you welded the image before cutting?
james605 and fivestar do great work with their printers and are reasonable!
Trick is hitting the right temperature over the entire surface of the graphic
in a year when the current cutter has made you some money move up a little and sell the old one! keep it up for a couple 3 years and you will be at the top of the heap wanting a eco printer!
congrats on the new machine looks awesome - hadn't looked at the summa before and wow those are some small drive rollers! should be a good solid machine
does he still have the Graphtec for sale??? pm with info if he does
dog running with scissors in his mouth
Dakotagrafx replied to bowhunter012004's topic in Graphic Requests
Don't have the graphic but have experienced it many times -
Check out the Sunie with wfree shipping
Basic XP Plotter Driver?
Dakotagrafx replied to Mac8's topic in USCutter Refine Cutting Plotter Discussion
Great info -
I am sure someone on here will do it for you but if you don't want to take the time and want a great job done at a reasonable price try a member that goes by drakesis. 9.00 per hr and does a great job. to do it yourself try inkscape
LP24 cutting 2-3 times on the same letter
Dakotagrafx replied to LOBO's topic in LaserPoint Cutting Plotter Discussion
++1 -
nice from shat I can see also
When you enter the cutting portion of signblazer are all 3 of the weed options unclicked?
problem with static is more on long cuts - also on the copams their was a problem with the dreaded line of death similar to this and the fix was to go flexi starter
2 choices - have the rollers outside f the cutting area or buy a more expensive cutter. They do go away when applied though
How do I draw simple flames? Newbie so be gentle!
Dakotagrafx replied to racejunkie's topic in SignBlazer
http://forum.uscutter.com/index.php/topic,3307.0.html -
http://www.signwarehouse.com/shop/merchant.mvc?Screen=CTGY&Category_Code=AT-MANT-PTP
Encad Croma 24 Wide Format Printer---help
Dakotagrafx replied to michaelf32's topic in General discussion
O would guarantee the lamination - these were not like the solvent or eco sol printers! and if it has the hp style carts as one f the versions had it ddin't even have the option of the go+ inks -
good job
company later sold to Kodak - is a 300 dpi printer hd two versions, one version did have Go+ inks available for printing outdoor stuff. check out global printing supplies to see cost of supplies. If it hasn't been used for a couple of months plan on new cartridges, etc -
Cutting Heat Press Vinyl
Dakotagrafx replied to VinlyDrop's topic in USCutter Refine Cutting Plotter Support Requests
heat press vinyl is pretty thin material and you only cut thru the vinyl leaving the backing material - which is removed after heat pressing. You aren't trying to cut thru the backing are you?
