Days Won
208
DPI is a raster term, doesn't apply to Vectors. For a logo that is to be cut you'd be better off designing in vector first then save export it to a raster format if/when necessary. How big are your logos that don't work? I know MH's have limited memory, but I have one, and have never ran into a memory problem and I've done some designs with a thousands of nodes. JLS, if you don't mind, I'd love it if you'd send me one of your designs that doesn't cut correctly and let me run it through mine just so I can see the memory problem first hand.
USB or serial? Vinyl/stand grounded?
Truck lettering (Using Vinylmaster Ltr v4.0)
darcshadow replied to a topic in VinylMaster CUT, LTR, PRO & DSR
Play around with different fonts. Fanklin Gothic Heavy at 6.3" tall will fill your 5' area. -
I've blasted at 60psi, with no issues, so long as the decal is not too detailed. Obviously the smaller the piece of vinyl the easier it'll lift/blow off. Applying to a textured glass like above would be the tricking part I would think.
I think you both missed his last post, the problem is software related, it doesn't happen with SignBlazer but does with VinylCutMaster. After you try reinstalling VM and the drivers, if that doesn't fix the problem I'd suggest contacting VM support.
Installation Disc Lost, need to installer plotter to new PC
darcshadow replied to Mace's topic in Roland Cutting Plotter Discussion
substitute the word foison for the word roland in Dakotagrafx's post. -
Resizing image using measurement between two points
darcshadow replied to Jeekinz's topic in General Help
And depending on the software you are using, there maybe a tool to do this. Signblazer has a measurement tool that can also be used to resize shapes/drawings. -
LaserPoint II NOT cutting exact dimensions
darcshadow replied to Detheredge's topic in LaserPoint Cutting Plotter Support Requests
I don't have SCALP but some where in your software there should be a scale factor you can fiddle with. Your machine is a stepper motor machine and I believe typical settings are 1000 steps per inch. Perhaps someone on here that uses SCALP can chime in and let you know where that setting is. If not, you could always try a different software and see if you can get the cuts correct. I know Signblazer allows you to adjust the distance per step as well as the cut extension for Inkscape.- 3 replies
- wrong
- laserpoint
(and 3 more)
Tagged with:
Relationship between Jog Settings vs. X and Y Scale
darcshadow replied to EAWF's topic in Creation PCUT Cutting Plotter Discussion
In the MH manual it specifies the number of steps per inch, 1000. I believe that is a pretty standard number for stepper motor cutters. I would expect that information is documented some place for the PCut but I don't know for sure. -
Looks like Aachen Std Bold You in Fort Worth?
- 1 reply
- 1
You looking for a design software or cutting software? Inkscape is a free design software that is just as capable as the big name software. It does take some learning and some aspects are not as straight forward as in other software but it is very capable and free. Signblazer is the only free cutting software I'm aware of.
There was a discussion along these lines just last week. You should be able to do it with VM LTR and above. If you don't have LTR or better it can also be done in Inkscape which is a free program, although it's not as straight forward as in other programs.
Laserpoint 2 - Parallel Line Issue
darcshadow replied to adventur Studios's topic in LaserPoint Cutting Plotter Discussion
Try making two straight parallel lines and closely watch the cutter head to see if it drifts at all. If not, and the cuts are not equal the entire run, then the problem is the vinyl slipping. If the cuts are both equal, then try doing it again, this time with the parallel lines about an 1" apart and a standing sine wave between the two cuts for the entire length. Assuming the two parallel lines are again equal the entire run, if the sine wave does not stay within the lines then the problem is the cutter head drifting. Still though, keep in mind this is a budget cutter using a stepper motor and you're wanting a 1/4" accuracy over a 12 foot long run, you're pushing the limits of what the cutter is capable of.- 13 replies
- laserpoint
- laserpoint ii
(and 3 more)
Tagged with:
I have this one a buddy asked me to make up for him. Don't know if he ever put it on someone's car or not. ParkLikeIdiot.svg
The tracking off while pre-feeding is likely due to not getting the vinyl perfectly square to the cutter.- 13 replies
- laserpoint
- laserpoint ii
(and 3 more)
Tagged with:
If you have that much trouble, might try Acetone or I've heard VM&P Naphtha works well for removing adhesives. Although they may damage the finish.
Settings for cutting onto contact paper
darcshadow replied to Daveischosen's topic in USCutter Refine Cutting Plotter Discussion
Depending on what you're using the stencils for, you might look at wall vinyl. It's easy to remove from most surfaces and so long as the surface is flat works well as a stencil. I've been using it lately for powder coating. -
So what was the fix?
I'd think it'd be easier to just use 1/4" pin striping tape. Regarding the tracking issue, have you messed with the pinch rollers? Do you pre-feed the 12' or so of vinyl first?- 13 replies
- laserpoint
- laserpoint ii
(and 3 more)
Tagged with:
Problemas para cortar esquinas / Problems to cut corners
darcshadow replied to TamaraVL's topic in Vinyl Cutters
What is your overcut set to? Try increasing that a little. -
When you say 2" drift what exactly are you referring to? I've used a MH to cut a 6' long 4" wide strip and the start/stop point was only off by about a 1/8" of an inch. And I'd strongly suggest taking down nearly all of those images on instagram. You're just asking from trouble from Disney and Dodge.
What format are the images in questions? Do they have a thumbnail of the image in windows explorer? If they are SVG files, there is a free program that will enable thumbnail views in Windows, SVG Explorer Extension.
sc pinch rollers leaving marks
darcshadow replied to cardudenc's topic in SC Series Vinyl Cutter Discussions
While I wouldn't recommend adjusting the pressure, if you do, do in in small increments, and do it equally across all points. I believe the SC pinch rollers have two screws on either side of the roller, if you want to adjust them, I'd suggest no more than a quarter, maybe a half, turn of each screw, on each roller to start with. If that doesn't solve the problem, and doesn't create any new problems, repeat till you either solve the indentation problem, or develop a tracking problem. Keeping the pressure equal is the key. Keep in mind, you will never get rid of the indentations, but once you peel the vinyl off the backing, the indentations should pretty much disappear. The indentations that you see are the vinyl conforming to the indentations in the backing paper, the vinyl itself should only have very very light indentations, if any at all. -
That's a pretty slick option in the software, but if you already have design software I wouldn't buy new software just for that feature. Manually scaling a drawing is pretty easy with Wildgooses technique, or you can just do some quick math as well. known measurement / on screen measurement * overall onscreen drawing measurement = new overall drawing measurement
NEED HELP!
darcshadow replied to mcmahan's topic in USCutter Refine Cutting Plotter Support Requests
What software are you using that says it needs the driver updated? Give Signblazer a try, it works well with the MH. Could also try using the Serial port rather than USB.
