Everything posted by cutme
i for one am very thankfull for all your hard work. i can't wait to get it! bb
thanks for all the great shop signs. bb
you have dot com and .com. should it be used once or twice? bb
is there a signblazer program version for Mac?
cutme replied to RMDelete's topic in Other Software Programs
no bb -
this is actually a real product on the market. bb
"I use the air eraser without a cabinet and do just fine....although you usually end up with a little grit in your teeth...and hair...and shirt."... AND LUNGS! DO NOT SANDBLAST WITHOUT A FRESH AIR MASK! FACEMASK RESPIRATORS ARE NOT RATED FOR SANDBLASTING. also ao has a static electricity problem that makes it hard to see what you are doing. silicon carbide is a little more expensive, but worth it. no static build up and discharge and it doesn't break down like ao. bb
liken' the sundowner! bb
not sure exactly what you are looking for here. looks like you are off to a good start. keep at it and you will find what you are looking for. maybe not right away, but you will get there. bb
Laserpoint 36'' Making Chatter When Feeding
cutme replied to Androidge23's topic in LaserPoint Cutting Plotter Support Requests
do you mean to say that the "chatter" noise happens when the material feeds? not when the cutter is moving left or right? sounds like the stepper motor or motor driver. just a guess. bb -
win7 32 bit here. works great. bb
all we really need to do, is find someone who could get into the pro/hotshot trial version and unlock it's outputs. we already have the full working versions, they just don't have the output functions. bb
you don't have to be better looking if you have more money... bb
.25, as in one quarter of a millimeter. bb
i don't think your problem is with signblazer. bb
in that video the vinyl should have been cut mirrored and applied to the bottom of the screen so the squegee would have no effect. and if you want to see how to do it properly, check out the videos at ryonet. bb
or you can split the objects and then delete at will... bb
when you are in the "print" window in sbe, hit the "f1" key. this will bring up all the "print" related help files. read through the file on the "fit" button. then soon you will be printing like a pro. bb
i think you are bumming on the .sm files. i don't know of any software that will even open that format. too bad you did not save as eps. bb
what i do to avoid this problem, is to create subfolders for eps and ai files so the two do not intermingle. bb
i have it on 2 win 7 machines, works great on both. bb
not sure what your problem is. i tried it by typing a lower case and an upper case j, then performed an expand function on them and it worked for me. bb
not sure exactly what the glitch is. i have created files in sb that would do that. bb
