gomer
Members-
Days Won
Everything posted by gomer
i know that, i want to know where there at in the program files, not how to change cutters in the program.
what i want to know is where the cutting drivers are stored that show up in the pic from Jay2703. C:/program files(x86)/Cutting Technologies/SignBlazer Elements/.....?
on my old pc it uses mh-871 driver. but what i really want to know what file the drivers are in.
i looked at that before i posted, i couldnt find what i was looking for.
i use 80 grit garnet sand in my blaster. since these glasses are thick and i'm blasting on a curved surface so i use 80-100 psi. i have used as low as 20 psi on some flat very thin glass. it takes forever to get something done when at low psi's.
does any one know why when i import an image that has 20 node points that SB adds 100 more that i have to go in and remove. the image looks the same, but there are unnecessary nodes.
i have tried every cutter in the list and non of them will connect to my cutter. does any one know what file the cutting drivers are in? i have another pc with SB that has the USC cutters in the list. could i delete the cutter drivers in the file currently and copy the drivers from my pc that works?
i finally spent the money for "diamond plate" vinyl, this is the first thing i did with it...... my work tool box before...... after..... i cant believe the difference!! i made some lettering for my friends truck windshield with diamond plate, as soon as he sends me a pic i will post it.
this is one of my favorite mirrors. i also have one of these vinyl decals on my tool box at work.
i made these for my uncle, he owns a lawnmower repair shop. its not vinyl, its blasted throught the color layer.
Just sand blasted my first mug, it came out awesome !!!
gomer replied to insert_coins's topic in Show your work
they look great. i have been doing this for about 2 years now. i will be starting a new thread with my work so check me out. -
Please help walk me though my install "new cutter"
gomer replied to torquen's topic in General discussion
i followed the link for installing the cutter as a printer, didnt work. i downloaded the file that it gave me if i didnt have the disc, nothing worked. i tried selecting a different cutter from the SB list and none of them find my cutter!! what is wrong!!!!!!! i hate windows 7. if i plug my cutter into my older pc it finds my cutter and is ready to use in about 5 seconds. but that is a backup machine. i use SB for cutting, and a refine eco mh-341 cutter. -
i have tried picking several cutters from the list and none of them will give me anything in the "output device" box.
So your cutter will not work with Windows 7, Here is a tip.
gomer replied to Addixionz's topic in SignBlazer
i am having a simular problem. my laptop died so i had to get a new one, the new one has windows 7. i finally got the patched SB copy installed and working. i have a eco refine cutter, and when i try installing the driver that came with it i get a "driver install failure" message and cant use my cutter. i tried using all the compatability modes for vist and xp and get the same thing. any ideas? my cutter is the mh-341 or ch-341. i have a backup pc with xp and when i am in SB i go to the cutter button, then set up it says i am using the "refine mh721" in the cutter. and next to output device it says "blazer com5:-usb-serial ch341a...." -
i kept my SBE install file that i got 2 years ago and it didnt count. i used it to install on a 2nd pc, and no counter. i used the same install on my new windows 7 pc and now i have a counter! how did that happen?? i uninstalled it and reinstalled it and still have the counter.
a few weeks ago my pc died and i had to get a new one. i put SB on it. i tried using the disc with the driver for the eco MH-341 that came with my machine, but i get a "driver install failed" screen. is there a fix on here that i didnt see? is there another way to install the driver?
-----WARNING------ i am not a programmer, IT pro, or even geek but i figured out how to make SB portable. start by watching the video then you need to download Cameyo from http://cameyo.com/.just follow the instructions and copy the packaged file to your flash drive, do NOT delete the original file just copy it to your drive. when you open the package the first time it will add a file with .data added to the end of the package name. TIP change the package name before you open it, if you change the name after opening the package it will create a new .data file with the new name next time you open the package. when you open the package cameyo will open a list of 4 options to open, you want the SB elemants file (first one on my list). i made some changes in my configuration so it opens faster , attempt at your own risk. open the .data file that was created after opening the package the first time. in it open VOS, then open Signblazer......, then find the wordpad file "virtapp". this is were i made changes. find the line autolaunch=%.... there are 4 file pathes here seperated by ;'s. the first one is the SB program file find the "......elements\SB.exe>>sign......" and change it to "....elements\SBnt.exe>>sign.....". this will skip the auto update (thanks to this forum for that tip). starting with the first ; i deleted everything after that down to the line starting with "shortcuts=%....". then i made the same changes in the shortcut lines down to "stopinheritance=" then save the changes, close the wordpad. then try opening the package. mine opens with the SB title logo then the normal registration window. it runs just like being on my normal PC. if you had problems or messed up or didnt understand what i was saying just delete the package and the .data file and copy the original back to your flash drive and start over. i did that several times before i got it right, thats why i said dont delete the original earlier. on a 0-100 scale of 0=cant turn a pc on, and 100= professional programmer i put myself at about 15. maybe a 16 after figuring this out.
my last comment for "rodger". i'm not even reading all your post anymore. using Cameyo is not illegal or "hacking" in any way. if an thing i am representing USCutter even more by being able to use it every were and not jumping to other software that you can buy on a flash already. before you say "hacking" is negative do your research on history. "hacking" has been going on since the begining of time and with out "hacking" nothing would ever advance. the term is used so loosley that i consider myself a "machine hacker" since i am a maintenance man. i fix, rebuild, and modify equipment to improve them. steve jobbs and bill gates are both "hackers" in the original sence, where would we be with out them. Tesla was a hacker. Einstein was a hacker. John Deere was a hacker.......do i need to continue? and the video says "the show were we break down concepts, tools, and techniques for hackers, guru's, and IT ninjas." Cameyo is a tool, the more tools you have the better. i am not a "hackers, guru, and IT ninja" but find it helpfull. if its not helpfull to you then forget you read it and leave us alone.
update......i was using my portable SB and did some 2 min drawings just to try it out. later when i was home i used SB that is on my PC and couldnt find the drawings. i though it wasent saving, but it was. i had to do a search and found them in the VOS C_ file. so if you think your version is not working just do a search before giving up.
i have a simple solution to the argument going on here......if you dont like what is being talked about in a thread, STAY OUT OF THAT THREAD!
your correct, SB dosent need the internet to operate. thats not the reason i posted this. yes you can install SB on every PC that you use, but why? if you install it once the way that i posted and you dont need to install, install, and install again. and if you are using a friends PC and they dont want your programs on there PC, you can still use SB (or other) on there PC from your flash and not put anything on there PC. and as stated above, "hacking" isnt always intended to create problems. there has been more benifits from hacking then hurt. but all we ever see is the hurt in the news.
i am using the refine eco. i have talked to support and they told me that there is no stand alone driver for the cutter, just that small file that works for signblazer. does anyone know if some one out there is makeing a stand alone driver that can be installed into windows? i would like to cut direct from autocad (2011 lt). when i change my autocad file to and eps to cut from sign blazer i always have to re-edit before i can cut and its a pain.
about me.....i am 29 and have been playing with vinyl cutting for almost a year. have made a few dollers from it but not a lot. i have the Refine Eco cutter, and run signblazer. i dont have any problems with SB or my cutter when i use only those 2 items. if i get an eps file i can import and edit fine. my problems come when i go out side of that. first thing i want to know is why i cant install my cutter as a plotter or cutter in windows printer file? i cant find anything online that helps me. software problems. i have autocad 2011 lt student from my college classes. i have inkscape, and as i said before SB. i can draw what i want in autocad but if i save it as a dxf and try opening it in SB it wont open it. so i open it in inkscape and save it as an eps. then back to SB. when i open it it looks ok at first, then i see all the missing and extra lines. i really want to be able to install the cutter as a plotter so i can cut dirrect from autocad. does any one have any suggestions for me. am i doing somthing wrong. i cant draw very well in ink or SB, is there a better way to convert from Autocad to SB?
