Wildgoose
Super Moderators
  • Content Count
    6,122
  • Joined
  • Last visited
  • Days Won
    247
Everything posted by Wildgoose
  1. Wildgoose
    Voice of Wesco
    Double check you haven't broken a tip. Happens sometimes and may effect the cut. Looking at the pic I would NOT think that's your problem. I am having a hard time figuring out why you have all the weird boxes associated with each letter. I see where the O in Robin has been overcut with one of the corners of a box. Strange looking job. I'd be interested in looking at the cut file in a basic format like .eps or similar.
  2. Wildgoose
    Any Tips On Applying Loaded Transfer Paper
    I just buy parchment paper at the grocery store in the cooking isle like you would use to bake cookies. Cheap stuff works great. Another option I have started doing is when I happen to do a local project that needs 3M/Gerber vinyl I buy the 225 as opposed to 220 cast vinyl. It comes on a clear synthetic carrier and save the backing for use when stacking or need to align things. Not sure in your location what the options are. I save all the clear backing I get my hands on. It also does a fair job of making paint stencils if you use a cutting mat or a few layers of app tape will work as well to create a carrier so you can cut out the stencil pieces.
  3. Wildgoose
    It sounds like maybe a build technique issue. If you are trying to align the word in a certain spot are you using some sort of tape hinge? Some layered work needs to be tight registration with other parts and the parchment paper works really good for that but just as often it's simply alignment with a substrate and if you are new you might not realize that most of us use some masking tape to get the design where we want it and hold it there. To be effective you will want straight edges or the hinge will go wonky. I usually trim my masked work with equal reveal on all sides to aid in keeping things straight on the install. I use a side hinge if possible and hinge it on the right side so I can flip it over and remove the carrier then handle the app tape with design with my left had while I squeegee my way across using my right hand (I am right handed). A top hinge or a bottom hinge is also functional and each of us develop our own methods that we like best. On really large graphics a center hinge is often used but takes practice and sometimes an extra set of hands. ALL of these require a little practice.
  4. I have found that backorders with ANY company are sketchy right now. I think it has a lot to do with the volatile offshore market. I am a Richardson Cap dealer and sometimes have to go buy them from a wholesaler who buys more than I do because the colors I want are out at Richardson and the backorders are approximate. I am sure that USCutter has similar issues with shipments. Like Slice mentioned (and others) it's a good idea to call ahead on big purchases. Or at least pay very close attention to the website availability.
  5. Wildgoose
    I’m back your warned!!
    All good, all good. LOL
  6. Wildgoose
    Yeaa Hatters back!
  7. You may have to wait for an update on the plug-in from Roland, thats one of the unintended consequences of the high zoot Illustrator CC, everyone has to try and keep up with the constant updates. I am running CS5 on 10.13 with only a small glitch in font view but is otherwise stable. I remember when I first bought CS5 I had lots of trouble with it being the newest out there for about a season. Now it's oldish but still gets me by and I don't pay rent.
  8. Wildgoose
    Layering vinyl questions
    Did you try popping them with a pin? It should let you bleed the air out of the ones big enough to poke. Sometimes smallish bubbles will work out over time but not a guarantee and it looks bad when someone buys something that has bubbles before they ever even install them. Paper tape is better too, and a lot more forgiving even if a little harder to align, but it can be done fairly easy when the background color is darker like that. If I am selling to self applicators I typically put registration marks and make them install in layers.
  9. Wildgoose
    HP Cutter Blades
    Thank you for the circle back. This really helps the future searchers.
  10. Wildgoose
    Adobe Illustrator
    Weird, I swear I responded to this already but must have failed to push send. I agree with Slice, no options without a plug-in from a third party program. I am an Illustrator guy and use SignCut Pro1 to speak to my cutter. If you bought the cutter you would have received some sort of program with it. You are in the VinylMaster section so I have to assume you have at least the CUT version? If so it will read a native AI file. I would suggest downsaving to version 8. Most of the CC versions have things that cause compatibility issues like multiple artboards etc....
  11. Wildgoose
    cobra ink epson printers
    That printer says it's not capable of photo prints so I am pretty sure that means it will not run the pigment based inks. So no I think the pigment ink would clog up immediately as pigment ink has suspended solids in the ink where regular office printing dye ink does not.
  12. Wildgoose
    Thoughts on the FC8600 Cutters
    You probably know this but if you are doing bike graphics you will also need to choose vinyl capable of good adhesion to LSE (low surface energy) plastics. There are several product lines out there but the hapless novice might try to use regular print and cut adhesive vinyl and have disastrous results.
  13. Wildgoose
    They are one of the very best available. Graphtec has earned it's reputation through years and years of happy customers. Bullet proof design and as long a life as any cutter on the market. You have to define "Best" choice though. If you are printing and contour cutting printed work I have always heard the Graphtec's struggle a bit with their optical eye finding the printed registration marks. I think the Roland's do better in that regard, however the Roland cutters are not known to be as tough and sturdy as the Graphtec. Summa makes a couple comparable cutters the SummaCut sits somewhere in between the CE and FC versions of the Graphtec. They are only rated to 400g cutting force but have phenomenal tracking and great optical eye. Its what I own although I do not print so I don't utilize the optical eye. The Summa T series is a true tangential machine that has the higher downforce like the FC but costs a few thousand more. Gerber makes some really nice machines as well but are obscene priced IMO. There are other high end brands out there too.
  14. Wildgoose
    Light Grey 651
    US Cutter sells several mat finished options in the 970RA wrap vinyl. https://www.uscutter.com/ORACAL-970RA-Wrapping-Cast-with-Rapid-Air-Technology-60in-Wide
  15. Wildgoose
    Best Transfer Tape
    I use the 4076 RLA as well. Sometimes 4075 which is almost as high of tack.
  16. I would almost guarantee this is correct. The added pinch rollers would help keep the material aligned during a high pressure cut but the strength of pull and the weight of the material is surely pushing the servo motors to their limit. I am no electronics wizard but there are surely some load limits the the motors have. You definitely have a unique situation where you can't really let the magnet lay down into the material catch bins.
  17. I think you would definitely benefit from the extra pinch rollers. I think I mentioned that I once considered an FC machine and they last who was the rep had a 30" model that had been set up to go to a sand blast outfit who would have been cutting blast resist which is similar in thickness to magnet. They had at least one extra roller maybe two and she said it was to help feed the material straight due to the heavy pressure of that thick a cut. I was going to pull them off for what I do and just save them for replacements or something.
  18. Wildgoose
    Pallet board stencilling
    I think it adds a little character to it having the paint go down into the seams a little like that. Looks great!
  19. Just for morbid curiosity I imported the dxf into Illustrator on my mac to see what size it would come in at. Came in at 106.084 mm. I have had trouble getting files to be at the right size most of the time when using dxf file formats in Adobe. If you know the size it's supposed to be I don't see why is makes a difference. You can just upsize it to the correct dimension in any vector program. Pretty sure that all the new cutters from Graphtec can get the software for free as long as it's a modern cutter. BUT I am not a Graphtec owner so it's not in my wheel house.
  20. I design on a mac and have mac compatible software (SignCut Pro1, which is strictly a cutter interface) but most of the time take my designs over to a cheap windows laptop and cut with that. More to do with keeping my design workstation unfettered than anything to do with the OS platform. I design in Adobe Illustrator as many mac users who cut do. The Graphtec FC series are going to be a much better option than the Roland. They are built for higher cutting pressures. Another option might be a Summa T series tangential cutter. They actually steer the blade around the corners rather than dragging the castor style blades all the drag knife regular cutters do. Using the higher downforce when cutting is going to translate into a lot more working force on all the components and that is why none of us want to use our pricey fine cutting machines to hack away at thick magnetic. At least the high end machines like the FC and the T Series Summa are built to take the abuse although it still makes me shudder to think of doing that to one. I have been wanting to step up to a tangential Summa machine (currently running a SummaCut drag knife) but not for the increased cutting power more for the increased accuracy that is supposed to be the case. I really just have this little devil that sits on my shoulder making me think I need one. I think if I were you and were considering spending the kind of dough that it's going to take for one of these high end cutters I would take a nice sized sample and go find a test machine and see if they can cut it like you want. Graphtec should be easy to find a dealer or a user somewhere near you, they are the most widely used name brand machines in the states. You will just have to find someone who cuts with the FC series. You might check with some of the sandblast people in your area. The local salesperson for Graphtec in my area has a couple clients that use the FC's for cutting blast resist which would be very similar to your magnetic. I almost bought an FC from her when I was upgrading.
  21. Any of you guys who run the lasers think you could cut with a laser? To klcjr - Magnets as mentioned are really hard to cut and hard on a fine tuned machine. Getting your cutter to cut accurately would be the very first thing you would need to do and you would want to start out by cutting some cheap sign vinyl which it's actually designed to cut. IF it's cutting regular vinyl at regular pressures ok but not the magnet then you will have an answer about whether your cutter has a problem or if it's related to the 30 mil issue. Assuming that it ALSO cuts out of dimensions then you will need to calibrate your cutter. Each cutting program goes about it a little different but they pretty much all have a way. If it's cutting sign vinyl at the correct size but not the magnet then you are probably not going to have success. The heavy magnetic material is likely more weight than your pinch rollers can keep hold of properly especially if you are dragging a knife blade through it. I have cut a few, and I stress FEW, like two times with my Summa. I did three passes at a regular pressure and it did ok. You also have a whole other part of the equation that you are probably not considering. You can't cut clear through any material without having some sort of carrier sheet. Vinyl and Heat Transfer Vinyl come on a carrier sheet. I seriously doubt your magnet does. I recommend if you keep trying and get it to cut satisfactory that you should leave just a little bit so the magnet is still one piece and then you can break it free. That's what I did on the couple that I cut. This will work for an occasional project but mass production is probably not all that viable. The big factories use a true die cutter and stamp cut them out I think. Very mass production.
  22. Wildgoose
    Signcut pro 2 configuration with MH365
    Here is a list of compatible cutters. http://www.signcutpro.com/files/pdf/driverlist20130410.pdf If for some reason you can't find it SignCut has actual tech support accessible from their website. I use the older version Pro 1. Signcut kicks butt
  23. Wildgoose
    weird values
    Do you have your drivers for the cutter to try reinstalling?
  24. Wildgoose
    weird values
    I have not seen anything like that. Have you created a ticket with tech support at Signcut? They have fantastic live tech support. It's been a while since I needed any help but if I remember correctly you request help from a portal on their website and they will contact you by email and if that isn't getting it done they step it up to a live person. I had an issue years back and they ended up doing some remote work on my computer to get me going.
  25. Wildgoose
    Another newby to the forum
    Hello and welcome from Idaho.
