Days Won
171
Everything posted by haumana
If you're getting the blue screen repeatedly, then there is something fundamentally going wonky with the OS. You might want to back up all your data, deactivate any software that can be, then reformat your machine. Even if you can get your cutter connected, the blue screen will keep on happening unless the issue is resolved. If you have assigned COM 2 for your cutter, then you should be selecting COM 2 in Flexi, not USB 2.
Got it. You can definitely change your screen resolution, so that everything becomes scaled bigger for you, or as Slice & Dice suggested, to increase the display to a larger percentage. Another great option is to hold the CTRL key and press the + key, that should enlarge what you're looking at.
Yes, that cable should do it. Cutter > Null Modem Cable > Keyspan > USB Cable > Computer
Google translation: "Good afternoon, I bought the vinyl cmaster v5 software and I cannot activate it as I do, please, it is urgent that I need to use it." You should contact the software company directly. We cannot assist with software activation issues. (Debe comunicarse directamente con la empresa de software. No podemos ayudar con problemas de activación de software.)
- 1 reply
- 1
Okay, let's try to get a handle on this - If you're wanting to use the serial connection on your cutter, then you need a null modem cable, not a "non null modem". Something like this: https://www.amazon.com/StarTech-com-10-Feet-RS232-Serial-SCNM9FF/dp/B00006B8BJ/ref=sr_1_1_sspa?crid=3SXMKWWEG0E4X&keywords=null+modem+cable&qid=1707691977&sprefix=null+modem+cabl%2Caps%2C196&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 That will tie into your keyspan, which you probably need to install the driver for, which you can find here: https://tripplite.eaton.com/support/downloads?type=software&subtype=31 Once you have the driver installed, and the cutter connected to you computer, go to Device Manager and see which COMPort was assigned by Windows. Make sure that you either reassign it, or that it's in the range between 1 and 4, no higher. Once you've verified which COMPort Windows is using for your Serial USB, go to Flexi, and make sure that the software is using the same COM number that is listed in the Device Manager. There should only be one.
Is the serial cable you're using a 'null modem'? Did your keyspan come with direction for a driver for the adapter? If you think Flexi is wanting to use COM3, then you can try and go into your Device Manager and reassign the Keyspan to be designated at COM3.
Please, please, please do no write in all caps. I also bought my first cutter from eBay, it was new, direct from US Cutter. You did not specify whether your cutter was new or used, but based on your response, I'm going to hazard a guess that it was used. You might want to check with the seller to see if they still have that information. If they do not, then your "free" option is to use SignBlazer. Slice & Dice was kind enough to provide the link for you. Again, pause your antivirus software to install SignBlazer.
Welcome to the forum. If possible, please try not to post in all caps, as I almost mistook it for spam, and came close to deleting the post all together. Have you consulted the manual for your cutter? It will guide you on how to properly setup your machine, including steps for connecting it via USB MH Manual: https://uscutter.com/content/PDFs/MH_Manual_09172019.pdf You do not need free cutting software, as it should've come bundled with VinylMaster Cut. Which can be downloaded here: https://uscutter.estore.software/downloads provided that you have your PSN (Product Serial Number), which should have been included with the cutter. If you truly want "freeware," then search this forum for the SignBlazer Elements download. You will need to disable your antivirus to install the software, but rest assured that if you downloaded it via this forum, it is malware and virus free. Please also note, that the original creator of the software has long passed away that the only means of 'support' is probably through this forum, which is contributed by volunteers. Good luck, happy cutting, and please keep us posted on your progress.
^^ This. The COMPort has to be 1 - 4, nothing higher.
If you leave the cutter plugged into the same port, then each time your machine starts/restarts, it should remain the same. On the software side, make sure it matches. If there's an option for 'auto' or 'auto detect,' still go ahead and select COM3.
What has changed in your environment? Did you move the cutter or. your computer? Did you unplug/replug your USB cable? How long is the cable from the cutter to your computer? Have you tried changing the cable, because they do sometimes go bad. If you're still wanting to try to connect via USB, then try to keep the COMPort to 1 thru 4. You can see what COMPort Windows has assigned to the device in the Device Manager, and you should be able to reassign the Port number.
amazingly, rebooting resolves so many things. glad you're back up and running again.
At least you think of things to draw. I fully admit to being a total left-brainer, next to no creativity, but I can execute the crap out of anything, or MacGyver when necessary, but fresh ideas is not something in my daily vocabulary.
Thanks for joining the forum. Looking forward to your posts.
Using Siser Romeo with Vinylmaster LTR
haumana replied to jillkmorgan's topic in VinylMaster CUT, LTR, PRO & DSR
True that. I've spent countless efforts making "incompatible" software work with different computers. It's like they're trying to test my ability to circumvent the way they want their program to install and run. Challenge accepted!! Clearly there are times when I simply have too much time on my hands -
If you can find out who the original manufacturer is for that machine, then you're 85% there. Then you'd be able to test out VM using the correct 'driver.' In the meantime, if you're designing in AI, but needing your format to be in .png, then just export your design from AI to a .png format. CorelDraw, Inkscape, and Affinity Designer also have the ability to do that as well. I rarely design in whatever proprietary software is provided to me, but I have a few machines that I need to use to send the job properly to it. -
You might want to design outside of the proprietary software (i.e. Illustrator, CorelDraw, Inkscape, Designer, etc.), and just import the graphics into the cutting software. Is VM able to export to a compatible format for the Romeo? -
that post is over 7-years old. try this link https://future.support/fr/blog/how-do-i-install-fonts-extras
If you're looking for quantity, you can check out SanMar.
post your file in .svg format and maybe someone can take a look at it.
White teflon strip required for CT630 Creation Pcut cutter
haumana replied to kainth.c.s's topic in Creation PCUT Cutting Plotter Support Requests
Try Aliexpress.com That's here I had to go to buy a replacment blade holder for my (first generation) LaserPoint. That was the only place I could find one. Though, I would recommend that if cutting strip is just simply too low, then to put tape or something else that will just build up the height, then put the strip over that. -
I only had the time to do a rough vector, then clean up should've been quick to do on the OP's side since it was just straight lines. It's good if they learn how to vectorize and node edit.
I am going to assume that this logo is painted on the side of your garage or something, since the forum frowns upon infringement. You might want to download Inkscape, it's opensource and free, work on mulitple platforms, and can be used to touch up and vectorize. That being said, here's a rough vector of your image, you will need to some editing to clean it up, but it shouldn't take long to node edit it. U.eps
MH871 MK2 Cutter Hits Hard when Running
haumana replied to Captain Coffee's topic in Community Rules & Announcements
Hey Captain - You can just scroll to the bottom and start typing up a response, or hit quote, or just add @haumana (or any other name), then that would usually notify the other member as well. I got the vid, and it's hard for me to say that the carriage to dropping with extra force. I would say to swap out the cracked blade holder when you get the replacement and try it again. I do know that my LaserPoint does drop the blade harder than my Graphtec, but as long as it's not poking holes through the back, and I'm still getting a good cut, then I'll just leave it as it is. Feel free to post your video in this thread if you would like others to chime in if they have any thoughts on this too. -
Definitely replace the blade holder and go from there. Do you feel that the blade holder is hitting with more force than normal?
