THier
Posts posted by THier
The Hasp driver is what your computer uses to recognize the dongle. I couldn't get mine to work with Win 7 until I updated the driver.
I don't see a specific win7 driver,,,, just use the vista?
Thanks,
Tom
Thanks,
Tom
What the he,,,,,ck is a hasp driver? Do you still have a link?
Thanks,
Tom
Do you have the dongle?
Yes,,, but windows 7 wants a digitally signed driver for it.
Do I have any hope of getting my SignBlazer 06 pro working? I need an easy way to do registration marks.
Thanks,
Tom
Have been using ImageStix (matt finish) to print decals on either an Epson pigmented or Dell color laser printer and then contour cutting. Pigmented shows signs of UV burnout after 6 months, laser held up somewhat better.
Have sheets of 3M ControlTac (gloss finish) laying around here that I had been told were receptive to laser printing. Your post finally prompted me to test a sample today and I am extremely pleased with the visual result. When time permits I will make a small decal to test the UV durability on our vehicle. This approach won't suit everyone; but for those who watch their budget, it may be an acceptable alternative to consider.
The Dell and ControlTac were given to us after a business shuttered their doors. They purportedly used this set-up to create exterior signage for their properties and vehicles; so I am hopeful this method has durabiliy.
So how satisfied are you overall with color laser on vinyl?
I am looking to get started,,, and if I can get away without investing thousands in a printer to start,, that would be a good thing.
Thanks,
Tom
Am I looking for a dye sub or something else?
Thanks,
Tom
The printer is dictated by what you want to print. I use an Epson 1100 or an Epson 1400 and a Roland CAMM 1 Cutter.
So any inkjet will work? With standard inks? I would be concerned about the ink in outdoor applications. Or is the media, vinyl vs paper the key?
Thanks,
Tom
It's not so stupid a question...There are some printer cutter combos that do both..I have a seperate system..Printer and a seperate cutter...My cut/print program places reg marks on the print and sends the same to the cutter...Once it's done printing I take it out of the printer and load it in my cutter..I align the reg marks and tell it to cut..It finds all four reg marks and then cuts my design..
I like my set up because I can cut while I print somethig else..If you print and cut on the same machine then you have to wait for it to finish both before printing or cutting something else..Matter of taste which you like better...
So what is required as far as a printer goes? Again,, I ASSUME it requires a special printer? I have google searched,, searched here,, and not finding any specifics.
Thanks,
Tom
OK,, I want to use my PCut to cut airbrush stencils,,, I figure inkjet photo paper would be a good stencil material,, yes or no? I have been experimenting,, don't know how far to push it, my latest attempt was 20 cut speed,, 225 pressure, with a 45deg blade, doesn't get it done yet,, but it is very close. I have 60deg blades ordered,, but don't have them yet. What are your thoughts,, should I increase pressure,, wait for the 60s, or use a different material. I have hand cut photo paper,, and they are reusable, but if I can cut with the PCut that is better for me. I have some thin cutting sheets that came from Bed Bath and beyond,, ( I think that is where the wife got them, but I don't want to ask yet,, 'cause she doesn't know they are "missing") I use repositionable adhesive to hold the material while it is being cut.
Thanks,
Tom
Is a contour cutter also doing the printing? I don't "get" contour cutting. I am assuming the printing is done on a different machine,, but you know what happens when you assume.
Thanks,
Tom
Oh,, just an update,, I WAS doing it incorrectly,, I dragged the two layers together,, and voila(sp) it cut correctly.
Tom
I think I may have just figured it out,, you drag the tiles on top of each other? I'll have to test cut tonight
I was given a graphic to cut out,, which is letters,, but as far as I know not a font. ( it was given to me as a .jpg) Anyway,, there is a "P" and an "O" that it doesn't cut the center out. Well it does cut it out but in a separate tile, How do I get it to cut it out all in one tile?
Thanks,
Tom
I tried a search,, but struck out,, I know this HAS to been asked before,, but
I have a Pcut I bought in 2005 or 2006,, As near as I can tell,, they use a Roland 2mm cutter?
Also,, is there a down side to using a 60deg blade for everyday cutting,, I am a hobbyist, not a pro.
Thanks,
Tom
Don't know if this is what you saw but here
Well that's not quite what I was looking for,, but will do if I can't find the other.
Thanks,
Tom
Ok,, years ago I saw a font and now can't find it,, it looks as if a monster or something clawed at the font,, (horizontally) I know this is an impossible question,, but maybe,,,, just maybe,,,, someone will know.
Thanks,
Tom
I just realized I had posted this in the wrong section,, so I copied it here
Thanks,
Tom
Ok,, Spent 3 hrs on the phone with Microsoft,, and Asus,, MS blamed it on Asus,, Asus blamed it on the driver,, so three hrs of my life wasted,, I am more leaning towards the Asus as being the problem. We tried to download drivers from Asus,, MS,, and still have the same thing. I am thinking this will be the last Asus machine I ever buy,,, The head phone port went bad shortly after I bought it,, (mechanical issue which won't let the speakers work) which I can live without,, I usually use head phones anyway,, but this issue kind of really ticks me off.
THANKS,
Tom
OK talked to customer service Monday,, I had them all stumped as well,, seems the digital device signature is an issue,, not really sure if I want to disable it through the registry,,, hmmmmmmmm. Thanks for all the help though. I may have to do design on this machine, and take my portable laptop down to the plotter.
Thanks,
Tom
OK,, Just tried something,, grabbed the daughters laptop,, (XP OS) loaded up signblazer, drivers ect,, plotter works fine!!!! So there is something with windows7. I would hate to have to steal daughters laptop back, not saying I wouldn't,, just saying I would hate to!!!!!
Thoughts?
Thanks,
Tom
Taz,, Great idea,, I hadn't thought of that,, unfortunately it is still a no-go,, DARN DARN DARN!
Any other thoughts?
Thanks,
Tom
sounds like you are referring to the driver that came with your usb to serial cable. You will need to either purchase a windows 7 compatible Usb to serial cable. Buy a Keyspan adapter. or go the Cable brand company website, and see if they have a windows 7 driver for your cable.
There is only a USB cable inline. My understanding is there is some sort of USB to serial conversion going on internal in the machine.
How many machines can I install on
in Sure Cuts A Lot Pro
I design on my laptop, e-mail to myself, then cut on a dedicated machine. Can I install on two machines?
Thanks,
Tom
